It is currently Thu Nov 19, 2026 1:38 pm
 Post subject: Have some apples on me.
PostPosted: Tue Jul 03, 2018 12:05 am  (#1)
ref: http://www.fontplay.com/freephotos/4thf ... 306-08.jpg
Pursuing this technique not just for watercolors but also for gouache and oils as well. :)
https://www.flickr.com/photos/34520999@ ... 1/sizes/o/
 Post subject: Re: Have some apples on me.
PostPosted: Tue Jul 03, 2018 12:08 am  (#2)
It really looks as a painting !
PostPosted: Tue Jul 03, 2018 12:18 am  (#3)
Thanks Diego. The trick is to feed FotoSketcher with an input created using G'MIC's new Sketch preset enhanced with a convolution layer created used 2 layers from the originaly, and bilateral smoothing of the top layer set to Grain Extract and merged down. Dup the covolution layer 1 or 2 times to taste and then copy visible to FotoSketcher using Painting 10 preset. I then blend that result with the same copy fed into G'MIC Cartoon (edge thickness set to 0 and 16 colors). Of course, for this result, I added some brushstroke blends that I outlined before and believe you created a preset for a while back. :)
PostPosted: Tue Jul 03, 2018 1:13 am  (#4)
simply fantastic! I like that look. :clap
