It is currently Thu Nov 19, 2026 5:34 am
 Post subject: Hidden Object Stereogram - All GIMP
PostPosted: Sat Apr 24, 2010 10:01 pm  (#1)
Figured out how to create stereograms "manually" in GIMP. No plugins, special filters, anything....It's a fairly simple process, although a bit repetitive. It's not perfect as stereogram programs have algorithms to minimize "ghosting" (aka "sliver" effects), which can be unsightly, but it's really cool to do it manually. Once I get the technique refined, I'll prepare a tutorial.
So, what do you see hidden in the texture? Click on the thumbnail to see a fullsize image.
Uploaded with ImageShack.us
 Post subject: Re: Hidden Object Stereogram - All GIMP
PostPosted: Sat Apr 24, 2010 10:26 pm  (#2)
Do I see a butterfly?
- Very cool stereogram! :yesnod
PostPosted: Sat Apr 24, 2010 10:27 pm  (#3)
Correct-o-mundo! Very good. :hi5
PostPosted: Sat Apr 24, 2010 10:46 pm  (#4)
Cool effect. I see the butterfly too. :bigthup
Out of curiosity, how many people can see both views of a stereogram? If you focus your eyes in front of the stereogram, you see one image and if you focus your eyes beyond the stereogram, you see the reverse image. One looks like it's floating, while the other looks like it's inside the image. Basically, one image looks like the inside out of the other one.
Am I making any sense at all? :gaah
I think it's kinda like the old wireframe box drawing. You keep staring at it and it flips position. Maybe not exactly like that but something similar is happening. :blind
PostPosted: Sat Apr 24, 2010 10:52 pm  (#5)
I know exactly what you're talking about. I can see both, too. I've been looking at them for so long, however, I can pretty much switch back and forth at will.
PostPosted: Sat Apr 24, 2010 10:57 pm  (#6)
It seems like sometimes I get stuck on one (usually the reverse) and can't seem to focus correctly to see the other image. :hoh Putting it up on my LCD TV, I was able to see both on your image. :2thup I think I'm going to be able to see these better on a big LCD TV. This is first time I've used my big LCD panel to look at one. :hehe
Doing this in GIMP will be cool. Can't wait to see the tutorial. :paint2
