It is currently Thu Nov 19, 2026 1:35 pm
 Post subject: Tapestral Bell
PostPosted: Tue Oct 02, 2018 1:06 am  (#1)
ref: http://www.fontplay.com/freephotos/seve ... 206-06.jpg
Just trying to motivate myself to actually rendering something for a change. :)
https://www.flickr.com/photos/34520999@ ... 2/sizes/o/
 Post subject: Re: Tapestral Bell
PostPosted: Tue Oct 02, 2018 7:45 am  (#2)
Very very nice, Lyle !
PostPosted: Tue Oct 02, 2018 10:26 am  (#3)
It does look like tapestry.
PostPosted: Tue Oct 02, 2018 12:19 pm  (#4)
Thanks for the comments. samj created a preset after I shared my flow with her and it's freaking fantastic. Adding color is just a matter of choosing the right blending techniques. :)
PostPosted: Tue Oct 02, 2018 1:01 pm  (#5)
Lyle, I am intrigued by that rendering a lot. Would you share your method or Samj's preset?
PostPosted: Tue Oct 02, 2018 1:43 pm  (#6)
Pat,
it could be:
GMIC>Testing>Lylejk>Lylejk test trw
You may try
(if Lyle confirms my impression)
PostPosted: Tue Oct 02, 2018 1:58 pm  (#7)
Just a try (very colourful…)
lodges-bushmans-kloof.ngsversion.1535731205489.adapt.1900.1_using Lyle preset.jpg
lodges-bushmans-kloof.ngsversion.1535731205489.adapt.1900.1_using Lyle preset.jpg [ 1.24 MiB | Viewed 2749 times ]
PostPosted: Tue Oct 02, 2018 2:04 pm  (#8)
Two other ones (still colourful, which I like).
flower_photograph_by_evestitch-dcn58mm_using Lyle preset.png [ 1.37 MiB | Viewed 2748 times ]
PostPosted: Tue Oct 02, 2018 2:09 pm  (#9)
Last one.
This one is for Pat.
the_tell_tale_heart_by_mouselemur-dc95oop_using Lyle preset.jpg [ 259.85 KiB | Viewed 2747 times ]
PostPosted: Tue Oct 02, 2018 3:09 pm  (#10)
Actually use Lylejk ribbon preset, Diego. Still, the results you achieved look fantastic, too. :)
PostPosted: Wed Oct 03, 2018 5:52 am  (#11)
Ran the ribbon preset at default. Only added another layer at hsl colour mode then using curves to lighten a bit more.
PostPosted: Wed Oct 03, 2018 9:08 pm  (#12)
Thank you Dinasset. Your imagea are really nice. Of course, you know how much I love cats!
Lyle, I will check your G'MIC testing folder.
PostPosted: Wed Oct 03, 2018 9:55 pm  (#13)
Thanks for the comments, Pat.
To Sallyanne; recommend toying with the diffusion tensor settings to get various outcomes to include wider loops and such. Also the colormode settings can be used to fill in the dark voids (did so for the original rendering blending grayscale output with monocrome output). :)
PostPosted: Thu Oct 04, 2018 4:57 am  (#14)
Thankyou Lyle :) . Waiting for it to render. The greyscale preview looks awesome already! If I like I will post. Doing the same pic.
PostPosted: Thu Oct 04, 2018 5:46 am  (#15)
Still not sure that it is the same or similar.
The greyscale was awesome. I still had to put the original over the greyscale for colour. This time I used the layer mode 'Lighten only'
PostPosted: Thu Oct 04, 2018 6:10 am  (#16)
Can also try re-apply the darken areas of the render to original or fill those areas with fabric texture. :)
PostPosted: Thu Oct 04, 2018 8:36 am  (#17)
Lyle, another successful look. Well done! :yes :cool
PostPosted: Thu Oct 04, 2018 10:51 pm  (#18)
Thanks, Issabella. To be honest, I actually like rendering crop circles better. lolol
