It is currently Thu Nov 19, 2026 1:35 pm
 Post subject: Maggot Sea
PostPosted: Sat Oct 06, 2018 9:46 am  (#1)
You're welcome to dive in. ;)
Had to do something for Halloween. lol
https://www.flickr.com/photos/34520999@ ... 1/sizes/o/
 Post subject: Re: Maggot Sea
PostPosted: Sat Oct 06, 2018 10:26 am  (#2)
I guess that is appropriate for Halloween!
PostPosted: Sat Oct 06, 2018 6:48 pm  (#3)
No, no, no, no! Now I feel all squeamish and icky!
PostPosted: Sat Oct 06, 2018 10:16 pm  (#4)
Come on, 2-ton. Don't you just have that desire to grab a handful and gulp down on these squirms? lolol
PostPosted: Sun Oct 07, 2018 2:28 am  (#5)
Ooh yuk (turns green). Only boys!! Too much protein. I would rather chocolate.
Lyle that must really appeal to your nature ;) Not bad from a 'single or small group' though :)
PostPosted: Sun Oct 07, 2018 7:49 am  (#6)
Thanks, Sallyanne. Yeah; started with a single maggot, then created 3 more using N-Point Deformation (slow but very fluid results) and commenced to wrap painting for the seamless texture. :)
PostPosted: Sun Oct 07, 2018 8:12 am  (#7)
you're sick!
PostPosted: Sun Oct 07, 2018 8:54 am  (#8)
I'll take that as a complement, Tran. lolol
At least it wasn't snakes (did that a few years back). lolol
PostPosted: Sun Oct 07, 2018 9:57 am  (#9)
Hey lylejk (or dinasset), you've used many filters
maybe you know of one that does this (or others that know of such thing).
Allows me to pixelize or mosaic of constant colors or return something that i can understand by script an image such that the pixel size changes dependent on similar colors.
So for example i feed it an image it looks at areas of similar colors and if the area of similar color is large it uses larger size (or returns larger size). if area of similar colors is smaller it returns the smaller size.
Pixelize only does contant size. I want the size to dynamically change based on similar colors around it.
Like if you were to paint an image using varying pixel sizes to match similar colored areas.
PostPosted: Sun Oct 07, 2018 9:55 pm  (#10)
Sorry for the belated reply (work 4 10-hr shifts on weekends (F-M)). Only thing that may address your query that I can think of is Ministick, Tran. It's under G'MIC>Array. :)
