It is currently Thu Nov 19, 2026 1:34 pm
 Post subject: Play
PostPosted: Sat Oct 13, 2018 9:05 am  (#1)
Run out of time tonight.
I had a little play from a 'flame' which I created in gimp and come up with
If I can remmeber correctly. I started with a star shaped flame, then made it bolder, continuous droste. Conformal map. Then I ran GMIC's Kaliedescope on it. bumped it through the lighting effects. By this time the background was a colour I didn't want so I overlayed it onto something else. Kaleidescoped using gimps this time a few times bumped again using map bump map so the flame would stand out more. I still didn't like the colour so inverted the colour and I think that is all. Image
OK I did some more with it
 Post subject: Re: Play
PostPosted: Sat Oct 13, 2018 12:15 pm  (#2)
Very nice, Sallyanne.
PostPosted: Sat Oct 13, 2018 1:44 pm  (#3)
Both designs are pretty!
PostPosted: Sun Oct 14, 2018 6:12 am  (#4)
Thank you :)
PostPosted: Sun Oct 14, 2018 7:14 am  (#5)
A bit early for baubles but I like it Sallyanne. :)
PostPosted: Sun Oct 14, 2018 8:38 am  (#6)
started with a flame again tonight. Played with it a little and ended up with something resembling water?
I then went on to run a few GMIC filters on it and got these.
Image This is only 25% size. I did put one the twice :oops:
For a better look
https://www.flickr.com/photos/115367823 ... 0/sizes/o/
PostPosted: Mon Oct 15, 2018 12:45 am  (#7)
Sallyanne, those are beautiful patterns!
PostPosted: Mon Oct 15, 2018 1:03 am  (#8)
Play for play.
Using your initially created pattern (nice).
PostPosted: Mon Oct 15, 2018 1:09 am  (#9)
Cool dinasset :)
PostPosted: Mon Oct 15, 2018 1:21 am  (#10)
Maybe this is a use more in line with the pattern look: overimposed on one of my "aqua-look" outcomes.
PostPosted: Mon Oct 15, 2018 6:20 am  (#11)
hows this
PostPosted: Mon Oct 15, 2018 10:21 pm  (#12)
Very good, Sallyanne!
