It is currently Thu Nov 19, 2026 1:39 pm
 Post subject: Crochet plays
PostPosted: Sat Dec 01, 2018 4:21 pm  (#1)
I tried using Blender and dinasset's crochet plugin to make a 3d cloth.
Still figuring out the cloth simulation in Blender.
Also, one of the plugins (Colorful patterned crochet) asks for a pattern name; I can't use the ''wet'' default, it only works if I leave it blank - How can I fix this?
Original: https://pixabay.com/en/background-patch ... e-1241214/
Color and transparency:
Blender renders:
 Post subject: Re: Crochet plays
PostPosted: Sat Dec 01, 2018 5:03 pm  (#2)
You may use the pattern you like better, "wet" was referring to one of my patterns.
If you want to use one of these, here they are.
FFsmWetStone.7z [390.75 KiB]
Downloaded 237 times
PostPosted: Sat Dec 01, 2018 5:04 pm  (#3)
BTW, very nice creation, Dionisio.
PostPosted: Sat Dec 01, 2018 6:03 pm  (#4)
Thanks!
Is there a specific folder I need to put the patterns in?
PostPosted: Sat Dec 01, 2018 6:34 pm  (#5)
Interesting outcomes Dionisio. Haven't played around much with cloth in Blender, might have to check it out sometime.
PostPosted: Sun Dec 02, 2018 12:53 am  (#6)
Dionísio wrote:
Thanks!
No, as any other patterns set (I use a lot of them), place it in "patterns_storage" folder and activate it (if you are using ofnuts' addonscollectionmanager) otherwise directly in "patterns" folder of your gimp user folder.
PostPosted: Sun Dec 02, 2018 8:56 pm  (#7)
It is wanting to go in my plugins folder..have moved it to patterns
PostPosted: Tue Dec 04, 2018 11:15 am  (#8)
Dionísio wrote:
Thanks!
I'm trying to install the portable version of 2.10; I wanted to install this management addon. Is there a way to do it?
PostPosted: Tue Dec 04, 2018 1:10 pm  (#9)
Here my copies
OfnutsAddonMgr.7z [5.45 KiB]
Downloaded 201 times
Place into your portable pack /Preferences/plug-ins, like here
PostPosted: Tue Dec 04, 2018 2:06 pm  (#10)
The .py executes when I start GIMP, but I don't see the options shown in this tutorial (brushes sets): https://gimpchat.com/viewtopic.php?f=23&t=13277
I tried making the brushes_storage in the /preferences/ folder.
PostPosted: Tue Dec 04, 2018 2:43 pm  (#11)
You have to create all the …_storage folders in Preferences, like here
Then you have to fill the …_storage folder with one or more folders of the appropriated type, like here
At this point under Help select "brushes set..." and you will see the panel to activate one or more of those
PostPosted: Tue Dec 04, 2018 2:47 pm  (#12)
I understand, thanks!
