It is currently Thu Nov 19, 2026 12:33 pm
 Post subject: Gimpy and Gimpless
PostPosted: Thu Feb 21, 2019 2:08 pm  (#1)
I am new to Gimp and have never used Photoshop or Adobe. All I want to do is download an image and multiply that image and manipulate each one. As a simple example I want to take the shape of a heart. Place five of them on a page and each one I’d like to stretch the point at the bottom, or round the top, or rotate and make one thin, the other fat etc…So I copied a generic image off the internet and brought it into Gimp. When I start up Gimp, I get a large screen with a small white rectangle in the center. In the Layer tool box to the right, it says this is my Background. I assume this is my canvas. So here is when I’m challenged and I am working to figure out;
1. In order to work on this white canvas, I need to make it larger in order to have the 5 hearts be manipulated.
2. When I copy multiple images onto the canvas, I have found that the images have their own square white border. I found this out by trying to put two hearts closer together. I believe I can use the Color Picker Tool to cut the heart from it white square but I do not know how to copy and paste the heart only image to the white rectangular canvas. On the Layers Tool, I have the white rectangular “Background” and “Images” of the heart.
3. I do not know what a Floating Select Transformation is.
4. I suppose I can manipulate these hearts by using such tools as the Handle and/or Cage Transform tool.
 Post subject: Re: Gimpy and Gimpless
PostPosted: Thu Feb 21, 2019 2:42 pm  (#2)
The white border is the background of the jpg heart.
Since you are beginning, I don't want to explode your brain into deep space immediately by trying to post something too complex.
So, try this quick way first. If the image has 2 colors, white bg and red heart, this should work okay.
Menu: Select...by color. Click on the white background. Menu: Select...grow. Grow selection by 1px, click OK. Hit delete.
OR
1. Download transparent heart to your images folder. Google "heart png" and pick your favorite.
2. In Gimp. File: New, image width 1920, height 1080. (for a FullHD canvas)
3. Open the heart, select all and copy to clipboard. (ctrl + a, ctrl + c)
4, Switch to empty canvas. Menu: Edit/paste../as new layer.
5. Duplicate the heart (ctrl + shift + d or from menu: Layer/duplicate layer). Begin to manipulate the copy.
PS. If you don't know anything about image editing, I would advise to go through some basics first.
Like the wikipedia page for example, there's lot of 101 sites too. https://en.wikipedia.org/wiki/Image_editing
Will make things much easier in future.
PostPosted: Thu Feb 21, 2019 5:03 pm  (#3)
Welcome to Gimp Chat, clawson. :)
I'm sure you will learn everything that you have mentioned soon.
PostPosted: Fri Feb 22, 2019 11:04 am  (#4)
There are beginner tutorials here, do a few and you will learn the basics.
viewtopic.php?f=10&t=3315
PostPosted: Fri Feb 22, 2019 10:58 pm  (#5)
PostPosted: Tue Feb 26, 2019 12:07 pm  (#6)
I do not know how to write and thank you individually so Gracias to all who responded.
PostPosted: Tue Feb 26, 2019 12:42 pm  (#7)
Clawson, Escribiste "gracias" en español. Es tu lengua nativa? Espero que aprendas mucho en este foro, no dudes en preguntar tus dudas. :)
Saludos,
Issa
PostPosted: Tue Feb 26, 2019 1:54 pm  (#8)
There is also an easier way using path shapes, as paths can be manipulated just as anything else within GIMP. I'll make a short video and post it here, when it's done.
Guess we can't add zip or xcf files here. Hmmmm...
PostPosted: Tue Feb 26, 2019 7:55 pm  (#9)
The tutorials are great and I am playing around with them BUT one of a few things I have yet to grasp is the background. When I open a new create, there is the white postage stamp rectangle. If I use the move tool I can move the stamp to reveal a checkerboard rectangle. So which is the canvas I am drawing on and which is the desk?
PostPosted: Tue Feb 26, 2019 8:32 pm  (#10)
My video tutorial is up on YouTube so you can view it:
Heart Shaped Paths
The checkerboard you see indicates the image has an alpha channel = transparent background. When using layers on any of your images, make sure you always select transparent layers, so that any image with transparencies (PNG files) will show correctly.
Addendum: I need a new microphone, my voice seems "MUFFLED". In reality it is not. :)
PostPosted: Wed Feb 27, 2019 7:01 am  (#11)
Thank you mahvin, it's very well explained and I learned again:
1.I would not have thought of doing this result using paths.
2.I did not know that you could open an image in Gimp directly from a site.
PostPosted: Wed Feb 27, 2019 1:12 pm  (#12)
Excellent tutorial, I learned a lot just by watching.
PostPosted: Tue Mar 05, 2019 3:28 pm  (#13)
Thank you Mahvin
PostPosted: Wed Mar 06, 2019 5:18 am  (#14)
Cool tut
by the way welcome to Gimp Chat clawson :)
PostPosted: Sat Mar 23, 2019 11:11 am  (#15)
Thank you all, it worked and I am now playing with it, FINALLY. It printed out very small and I tried to scale it up. I received a warning window stating I may have scaled it up too much but it still prints out too small. One other issue, is there a way to get these different simple projects on one sheet of paper? Copy and paste doesn't seem to work in GIMP.
Thanks again!!!
