It is currently Thu Nov 19, 2026 12:38 pm
Post new topic Reply to topic  [ 380 posts ]  Go to page 1, 2, 3, 4, 5 ... 19  Next
 Post subject: Variations On A Theme (now closed)
PostPosted: Fri Mar 08, 2019 3:15 am  (#1)
Theme 1
(text from: Giacomo Leopardi, Canti, A Silvia)
removed for GC policy reasons
'Art@ (83), using FPS01, on 30 areas, nuance=none.jpg [ 673.9 KiB | Viewed 9357 times ]
 Post subject: Re: Variazioni su un tema
PostPosted: Fri Mar 08, 2019 3:19 am  (#2)
2019-03-08 08-52-32 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Gra.jpg
2019-03-08 08-52-32 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Gra.jpg [ 1.06 MiB | Viewed 9355 times ]
PostPosted: Fri Mar 08, 2019 3:21 am  (#3)
2019-03-08 08-54-10 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Yel.jpg
2019-03-08 08-54-10 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Yel.jpg [ 1.21 MiB | Viewed 9355 times ]
PostPosted: Fri Mar 08, 2019 3:22 am  (#4)
2019-03-08 08-55-35 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Ora.jpg
2019-03-08 08-55-35 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Ora.jpg [ 1.2 MiB | Viewed 9355 times ]
PostPosted: Fri Mar 08, 2019 3:23 am  (#5)
2019-03-08 08-56-26 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Red.jpg
2019-03-08 08-56-26 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Red.jpg [ 1.12 MiB | Viewed 9355 times ]
PostPosted: Fri Mar 08, 2019 3:24 am  (#6)
2019-03-08 08-57-17 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Gre.jpg
2019-03-08 08-57-17 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Gre.jpg [ 1.17 MiB | Viewed 9354 times ]
PostPosted: Fri Mar 08, 2019 3:26 am  (#7)
2019-03-08 08-58-10 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Cya.jpg
2019-03-08 08-58-10 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Cya.jpg [ 1.18 MiB | Viewed 9353 times ]
PostPosted: Fri Mar 08, 2019 3:27 am  (#8)
2019-03-08 08-59-04 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Blu.jpg
2019-03-08 08-59-04 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Blu.jpg [ 945.12 KiB | Viewed 9352 times ]
PostPosted: Fri Mar 08, 2019 3:28 am  (#9)
2019-03-08 08-59-57 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Mag.jpg
2019-03-08 08-59-57 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Mag.jpg [ 1.08 MiB | Viewed 9352 times ]
PostPosted: Fri Mar 08, 2019 3:30 am  (#10)
2019-03-08 09-01-24 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Mix.jpg
2019-03-08 09-01-24 Duong Quoc Dinh TuttArt@ (83), using FPS01, on 30 areas, nuance=Mix.jpg [ 1.18 MiB | Viewed 9352 times ]
PostPosted: Fri Mar 08, 2019 9:59 am  (#11)
Dinasset :wvy
I really like this alliance poetry and graphics. :clap
FPS01 ??which filter?
PostPosted: Fri Mar 08, 2019 10:43 am  (#12)
FPS=FreePaintStyle (01 means the first).
After having spent a lot of time last year in trying to "imitate" the strokes of famous French painters of XIX. century, nowadays I prefer to feel free to use strokes at my taste.
This new thread is my version of your thread "For my pleasure".
I will put here my "divertissements".
PostPosted: Fri Mar 08, 2019 12:12 pm  (#13)
Such a beautiful poem and such beautiful outcomes, they match perfectly. Thanks for sharing it. :bump
PostPosted: Fri Mar 08, 2019 6:24 pm  (#14)
I think this style is very nice. I admire all of your images. Will this script be available?
Or something of your own. If so, I understand.
PostPosted: Fri Mar 08, 2019 10:25 pm  (#15)
level_0 wrote:
Dinasset :wvy
Sorry, the texts have been removed, for GimpChat policy reasons.
To translate poetry is non-sense: poetry is not made only of contents, hence I decided to remove the Italian texts.
PostPosted: Fri Mar 08, 2019 10:28 pm  (#16)
At the end of my experiments, if you still like the outcomes, you will get the script.
 Post subject: Re: Variations On A Theme
PostPosted: Fri Mar 08, 2019 10:45 pm  (#17)
Theme 2
(text from: Giacomo Leopardi, Canti, L'Infinito)
please read it by yourself, if you like
2019-03-09 04-33-05 photo-1525638293492-d0b465b5f77e, using FPS02, on 30 areas, nuance=none.jpg
2019-03-09 04-33-05 photo-1525638293492-d0b465b5f77e, using FPS02, on 30 areas, nuance=none.jpg [ 723.1 KiB | Viewed 3800 times ]
PostPosted: Fri Mar 08, 2019 10:45 pm  (#18)
2019-03-09 04-34-25 photo-1525638293492-d0b465b5f77e, using FPS02, on 30 areas, nuance=Gra.jpg
2019-03-09 04-34-25 photo-1525638293492-d0b465b5f77e, using FPS02, on 30 areas, nuance=Gra.jpg [ 1.09 MiB | Viewed 3800 times ]
PostPosted: Fri Mar 08, 2019 10:46 pm  (#19)
2019-03-09 04-35-22 photo-1525638293492-d0b465b5f77e, using FPS02, on 30 areas, nuance=Yel.jpg
2019-03-09 04-35-22 photo-1525638293492-d0b465b5f77e, using FPS02, on 30 areas, nuance=Yel.jpg [ 1.17 MiB | Viewed 3800 times ]
PostPosted: Fri Mar 08, 2019 10:48 pm  (#20)
2019-03-09 04-36-18 photo-1525638293492-d0b465b5f77e, using FPS02, on 30 areas, nuance=Ora.jpg
2019-03-09 04-36-18 photo-1525638293492-d0b465b5f77e, using FPS02, on 30 areas, nuance=Ora.jpg [ 1.15 MiB | Viewed 3800 times ]
