It is currently Thu Nov 19, 2026 12:32 pm
 Post subject: Fancy Place Card Design (3 Pack)
PostPosted: Sun Mar 10, 2019 5:47 pm  (#1)
Here's is the "Fancy Place Card Design" 3 pack,
made using Gimp 2.8.18.
File comment: This zip folder contains 3 xcf files,
of the images seen above.
Fancy Place Card Design (3 Pack).zip [136.79 KiB]
Downloaded 224 times
 Post subject: Re: Fancy Place Card Design (3 Pack)
PostPosted: Sun Mar 10, 2019 10:56 pm  (#2)
All 3 are really nice.
PostPosted: Sun Mar 10, 2019 11:08 pm  (#3)
Thank you 2-ton. :coolthup
PostPosted: Mon Mar 11, 2019 3:45 am  (#4)
Good design work, I like the art deco one especially. :paint
PostPosted: Mon Mar 11, 2019 5:46 am  (#5)
Wallace has some path tool skills !
Do you use a grid and spirals or is it all free hand ?
Btw, these spirals and flourishes are a lot more easily done in Inkscape with the Bezier Tool in Spiro-Spline mode.
PostPosted: Mon Mar 11, 2019 10:22 am  (#6)
Thank you Tas_mania.
Thanks Konstantin.
For the most part,
I do it freehand and only use guides for the straight runs of paths,
where I feel it's needed.
You're right about Inkscape.
I've used it to create glyphs for a font I made.
Then imported them into Fontforge.
The font is loosely based on the handwriting style,
of cartoonist Robert Crumb.
Here's a screenshot of the font I made.
PostPosted: Thu Mar 14, 2019 3:47 am  (#7)
Wallace, you are extremely talented in many types of art.
PostPosted: Thu Mar 14, 2019 1:07 pm  (#8)
Very nice, Wallace. Did you used Paths or you have swirl brushes you created?
This are really good for simple Wedding invitations. :yes
PostPosted: Thu Mar 14, 2019 1:18 pm  (#9)
Thank you Pat. :bigthup
It's all done freehand,
using the paths tool.
