It is currently Thu Nov 19, 2026 12:32 pm
 Post subject: Google Text Logo
PostPosted: Wed Mar 20, 2019 5:34 pm  (#1)
Here's a google text logo I made by following a wiki tutorial and a photoshop one & combining them.. or at least trying to:
Google Text Logo:
Wiki Tutorial:
https://www.wikihow.com/Create-the-Google-Logo-in-GIMP
Photoshop Tutorial:
https://www.youtube.com/watch?v=BK2tKkPHwDs&t=180s
 Post subject: Re: Google Text Logo
PostPosted: Wed Mar 20, 2019 9:51 pm  (#2)
Google Text Logo:
Wiki Tutorial:
Photoshop Tutorial:
That's pretty good.
Would be even better with an inner bevel added.
This one I made using Bevel Reflect.
PostPosted: Thu Mar 21, 2019 12:18 am  (#3)
Google Text Logo:
Wiki Tutorial:
Photoshop Tutorial:
That's pretty good.
That's pretty good too, Wallace. :bigthup
PostPosted: Thu Mar 21, 2019 12:22 am  (#4)
mackenzieh wrote:
That's better pretty good too, Wallace. :bigthup
Thanks.
Bevel Reflect Logo is pretty nice.
I ran it for each color,
using a custom gradient.
PostPosted: Thu Mar 21, 2019 12:55 am  (#5)
Thanks.
That's cool. I will try that next time.
PostPosted: Thu Mar 21, 2019 12:08 pm  (#6)
Nicely done mackenzieh and Wallace :bigthup
I'm using inner shadow instead of bevel.
It seems that they had lifted the small letters upwards a bit in the old logo.
The "l" letter is also bending slightly right in the font file, but in the logo it was straight.
Disregarded details to keep the text information of original layer.
1920x740 canvas
Font: Catull, 550. Letter spacing -8.0
Highlighted letters individually, used blue, red, green and yellow to color.
Layer Effects:
Drop Shadow: Direction 100, size 10, opacity 60. Rest settings default.
Inner Shadow: Blend mode grain merge, opacity 100, angle 120, distance 0, edge, choke 34, size 78.
Duplicate layer.
Inner Shadow: Blend mode Addition, opacity 35, angle 120, distance 12, Choke 34, Size 78.
Google-Old.xcf [803.48 KiB]
Downloaded 142 times
PostPosted: Thu Mar 21, 2019 12:18 pm  (#7)
1920x740 canvas
Layer Effects:
Duplicate layer.
Thank you Nidhogg.
That's a fine example of the google logo.
:coolthup
