It is currently Thu Nov 19, 2026 12:31 pm
 Post subject: Colored dowels
PostPosted: Tue Jul 02, 2019 12:45 am  (#1)
ref: http://www.fontplay.com/freephotos/fift ... 906-03.jpg
As opposed to dolls. lol
Used Shapeism (G'MIC) in creative ways for this result. Used several other G'MIC presets too and then blended in the texture. :)
https://www.flickr.com/photos/34520999@ ... 2/sizes/o/
 Post subject: Re: Colored dowels
PostPosted: Tue Jul 02, 2019 1:24 am  (#2)
:coolthup
PostPosted: Tue Jul 02, 2019 1:39 am  (#3)
Thanks Sallyanne; now I really need to hit the hay (1:39am). lol
PostPosted: Tue Jul 02, 2019 5:12 am  (#4)
Good result. :clap
PostPosted: Tue Jul 02, 2019 1:35 pm  (#5)
That's nice, I like how the colours have turned out.
Ran couple tests but didn't manage to get as thin lines. Did you use dilate?
PostPosted: Tue Jul 02, 2019 8:16 pm  (#6)
Indeed I did, Nidhogg. Can't always share all of my secrets (actually used G'MIC's Morphology filter since it works on transparencies).
Also appreciate the words from you too, kungfu07. :)
