It is currently Thu Nov 19, 2026 10:46 am
 Post subject: Stick Your Tongue Out.
PostPosted: Tue Jan 28, 2020 1:07 am  (#1)
ref: http://www.fontplay.com/freephotos/fift ... 409-05.jpg
Marbles do lead to cobblestones (if you know the secret). :)
https://www.flickr.com/photos/163034485 ... 37/sizes/o
 Post subject: Re: Stick Your Tongue Out.
PostPosted: Tue Jan 28, 2020 1:19 am  (#2)
Lyle, Wow! I love your result, it is great in spite of being an ugly guy. :hehe :clap
PostPosted: Tue Jan 28, 2020 1:22 am  (#3)
Thanks Issabella. Have to say, though, that beauty is in the eye of the beholder (and so is ugly). lolol
PostPosted: Tue Jan 28, 2020 1:24 am  (#4)
Not ugly, just a typical feature of the Maori people of New Zealand and their art. They also rub noses as a form of greeting.
PostPosted: Tue Jan 28, 2020 3:43 am  (#5)
Getting better at these marble effects lyle.
But seriously, why can you portray a Maori god with marbles but not the president of the US with marbles on Gimp Chat?
I was born in NZ and don't have an issue with how Maori traditions are treated, but I hate inconsistencies and contradictions.
I think we need to update the Gimp Chat site policy just a bit to really reflect a global view.
PostPosted: Tue Jan 28, 2020 5:17 am  (#6)
I'm so sorry. I didn't want to offend anyone. I wanted to make a little joke about Lyle's outcome. But because of my natural way of being, I respect all the traditions of any culture being in the world.
PostPosted: Tue Jan 28, 2020 7:03 am  (#7)
lylejk,give us the secret! :) ;)
I like the outcome.
PostPosted: Tue Jan 28, 2020 10:40 am  (#8)
[quote="lylejk"]ref: http://www.fontplay.com/freephotos/fift ... 409-05.jpg
[img]https://live.staticflickr.com/65535/49453737637_04747ca315_b.jpg[/img][/quote]
PostPosted: Tue Jan 28, 2020 3:30 pm  (#9)
I like the outcome.
Output of the Voronoi Stippler mask fed into lylejk stencil (another preset that David saved for me and am grateful for it). Have to play with the sliders; if you go too far, you get bridging (and even with this result, I do see a few stones that bridged). :)
PostPosted: Tue Jan 28, 2020 4:22 pm  (#10)
That's real nice looking lylejk, I like it even more than the marble version.
It must be laughing to me for rushing to install Focal Fossa earlier...was not great idea from gimp's point of view because my mar-ball technology is dependent on one of Tim's python files. Luckily I have Mint19 on another machine to continue.
PostPosted: Wed Jan 29, 2020 4:24 am  (#11)
lylejk :wvy
Does the dinasset Voronoi indicate it here (# 27):
viewtopic.php?p=219143#p219143
can give similar results?
PostPosted: Wed Jan 29, 2020 5:13 am  (#12)
@level_0
The effect of my "Fake Voronoi" is this.
IDK if it can approximate what you like to have.
2020-01-29 11-10-05 4c15487f1c8f3967eda633db5f49005c, filled with fake Voronoi.jpg
2020-01-29 11-10-05 4c15487f1c8f3967eda633db5f49005c, filled with fake Voronoi.jpg [ 2.67 MiB | Viewed 2885 times ]
PostPosted: Wed Jan 29, 2020 6:54 am  (#13)
@level_0
no but i will try it ! :) thanks for the capture,dinasset.
PostPosted: Wed Jan 29, 2020 7:01 am  (#14)
There is quite a difference, stippling applications like StippleGen2 can calculate the voronoi path over and over to make it perfect.
Couldn't get the old voronoi stippler Lylejk uses to run on Win10 64-bit.
6070 stipples, min dot size 1.25 (too small for marbles if you're doing them from pixels, but in my workflow they will be done using the generated .svg voronoi path), dot size range 1.15.
Each generation, of the 30 took about 15-20 seconds to finish.
The image used for stippling was washed-out version of the original Trump image.
Stippled. I think this is good base because the stipples scatter over the canvas fairly evenly.
You just can't make it out well in BW.
PostPosted: Wed Jan 29, 2020 10:30 am  (#15)
I wanted to try the EasyVoronai plugin from dinasset but I realized that it needed patterns or something else because Gimp froze ...
PostPosted: Wed Jan 29, 2020 10:42 am  (#16)
Here they are, just for you...
and here the filter, just in case you have an old version
edit: attachments removed, see specific thread
PostPosted: Wed Jan 29, 2020 11:43 am  (#17)
Thank dinasset :hugme
the version that froze the PC was that of the link I indicated in my previous message (plugin "DIEGO_QUANTIZE_EasyVoronoi.py of 10Kb)
PostPosted: Wed Jan 29, 2020 12:47 pm  (#18)
Oh, I see, level_0 (BTW, could I know your name? It would be nicer than level_0...).
That's an old 2.8 filter.
Here an example of the outcome, using the same input source.
Do you prefer this one?
PostPosted: Wed Jan 29, 2020 2:14 pm  (#19)
I really like that outcome dinasset.
PostPosted: Wed Jan 29, 2020 2:35 pm  (#20)
Thanks, you may experiment it yourself, here the filter and a set of (required) patterns.
