It is currently Thu Nov 19, 2026 10:47 am
 Post subject: add multiple guides
PostPosted: Sun Mar 08, 2020 2:08 pm  (#1)
since I work with 2.10 there is always a problem somewhere that pops up.
I want to install add multiple guides, but despite the fact that the plug is perfectly installed, it is not visible.
can someone give me the plug-in, maybe mine is not valid.
gimper66
 Post subject: Re: add multiple guides
PostPosted: Sun Mar 08, 2020 4:22 pm  (#2)
Why do you have your plugins in their own folder? Just put them in the Plug-ins folder. Here is a modified version of add multiple guides. It works just fine here.
add_multiple_guides_plug-mod.py.zip [2.12 KiB]
Downloaded 273 times
PostPosted: Mon Mar 09, 2020 3:18 am  (#3)
racer-x,
I have put your plug-in in my own folder,then I placed it in my plug-in folder and it now works perfectly.
I rather think that there was something wrong with the plu-in that I used, how else can it be that the plug-in you provided me works perfectly.
Thank you very much for your quick response,I can now draw lines again at will.
PostPosted: Mon Mar 09, 2020 4:30 am  (#4)
gimper66, :wvy
you asked for this plugin here:
viewtopic.php?p=246605#p246605
and rich2005 had given this link to download it:
https://www.gimp-forum.net/attachment.php?aid=1950
(I have rich2005 and it works well in samj 2.10.14)
PostPosted: Mon Mar 09, 2020 8:17 am  (#5)
level_0 wrote:
gimper66, :wvy
thanks level-0
but racer-x gave me the plug-in and that works perfectly now.
PostPosted: Mon Mar 09, 2020 1:02 pm  (#6)
gimper66 wrote:
racer-x,
You would need to compare both plug-ins side by side.
To determine what the discrepancy/differences is between these 2 plug-ins.
