It is currently Thu Nov 19, 2026 9:20 am
 Post subject: Textured Petunia
PostPosted: Wed Apr 08, 2020 9:55 am  (#1)
ref: http://www.fontplay.com/freephotos/fift ... 606-05.jpg
Just can't help myself. Made it more mosaic than stained glass (i.e, grout outline instead of leaded joints). Still on this binge; will it end? Who knows. lol
https://www.flickr.com/photos/163034485 ... 76/sizes/o
 Post subject: Re: Textured Petunia
PostPosted: Wed Apr 08, 2020 1:52 pm  (#2)
Very nice glass effect, it gives me good vibrations :clap
PostPosted: Wed Apr 08, 2020 3:16 pm  (#3)
Can't beat Eye Candy for it's effect. If they weren't so PS complacent (new versions that is), I'm might even splurge to get the plugin since some of the effects of the newer plugins are beyond awesome. Even this old version of Eye Candy has no real equal for what it's capable of doing with bitmap images. Trick, again, for using glass on transparent layers is to lock the transparent layer before running the preset (if you don't, you get a blank result). Only recently found this one out (and by accident). :)
