It is currently Thu Nov 19, 2026 9:23 am
 Post subject: Something else to play with
PostPosted: Thu Apr 16, 2020 11:50 am  (#1)
I meant to do this once a week, but I've missed last week. Here's another photo to play with:
Kevin
 Post subject: Re: Something else to play with
PostPosted: Thu Apr 16, 2020 2:10 pm  (#2)
You just had to continue to feed my binge hadn't you, Kevin. lol
Thanks for the play. Bushed I am (had to pull a 6 hour last night). Still, I needed the diversion. :)
PostPosted: Thu Apr 16, 2020 11:12 pm  (#3)
Really excellent Lyle !
If you used only Gimp and Gmic, maybe you will post your tut, as you did years ago, from which I derived my script "Lyle style".
If not, we should just enjoy your creations...
PostPosted: Thu Apr 16, 2020 11:43 pm  (#4)
That's superb Lyle!
PostPosted: Fri Apr 17, 2020 12:00 am  (#5)
My very limited "sharpen-blur" approach.
difficult to notice the difference, only side by side
PostPosted: Fri Apr 17, 2020 12:14 am  (#6)
PostPosted: Fri Apr 17, 2020 1:01 am  (#7)
Edge detection is key, Diego; Isophots is just too, well, not accurate. Again, I used Neon Edge detect (with some cleanup) and then squeezed the lines further using G'MIC's Skeleton (slow). Once I got the edge template, I selected the background (due to using neon edge, the background color is black) before running Mosaic Tiler Helper. I then, of course, stroked the dots and ran Skeleton (fast) for the mask. I cleaned the mask, again, but up, set top layer to light, and moved up, dupped that result set to lighten, and shifted other directions to get a cleaner mask since Skeleton (fast) output is not the cleanest. Need the wider lines for the mask in order for the blend shape average step to get a solid clean result (no side artifacts). Added the isophots steps outline like I did in the tutorial is not needed so long as you have a thick enough mask for blend shape average. Just running morphology to thicken the masked still led to an ugly outline. The shift lighten technique, though eyeballed, just gives a cleaner result imo. As for tutorials, as you know I don't like doing them and now that I have to hit the hay since I have to head to work tomorrow for my version of Monday, I don't have the motivation (since I worked Monday into Tuesday and Wednesday into Thursday this week for overtime pay, I really never got a solid day off, either; like the extra pay, but you cannot put a real price on having 3 straight days off). lol
PostPosted: Fri Apr 17, 2020 1:43 am  (#8)
Thanks a lot, Lyle.
This is what I was asking for: the sequence of steps, not a "tutorial" in the classical sense, sorry for having used that word.
I don't like tutorials either.
PostPosted: Fri Apr 17, 2020 4:34 am  (#9)
:wvy
I like tutorials because that's how I learn and then I modify them as I like ... :)
PostPosted: Fri Apr 17, 2020 9:14 pm  (#10)
My play.
PostPosted: Sat Apr 18, 2020 12:26 am  (#11)
My try,
PostPosted: Sat Apr 18, 2020 1:43 am  (#12)
Very nice, Issabella.
PostPosted: Sat Apr 18, 2020 2:10 am  (#13)
Nice b/w Noir, Issabella. :)
PostPosted: Sat Apr 18, 2020 10:28 am  (#14)
Thank you so much for your appreciation, Dinasset, and Lyle. It means a lot to me. :tyspin
PostPosted: Sat Apr 18, 2020 7:24 pm  (#15)
PostPosted: Sun Apr 19, 2020 8:16 am  (#16)
Structure
PostPosted: Sun Apr 19, 2020 8:19 am  (#17)
I am late to the game!!!
I decided to do something silly and give each flower a picture of it's own!
david.
PostPosted: Sun Apr 19, 2020 8:43 am  (#18)
I love seeing your creations. You all have become the roses admirable creations. :clap
