It is currently Thu Nov 19, 2026 9:24 am
 Post subject: turn photos into sketches
PostPosted: Mon Apr 20, 2020 1:29 pm  (#1)
Gmic hard sketch
 Post subject: Re: turn photos into sketches
PostPosted: Mon Apr 20, 2020 10:24 pm  (#2)
BMWr18
PostPosted: Mon Apr 20, 2020 11:50 pm  (#3)
Sketches came out great, itzaf. :)
PostPosted: Tue Apr 21, 2020 9:36 pm  (#4)
Thanks You
PostPosted: Wed Apr 22, 2020 3:01 am  (#5)
ilzaf :wvy
I like :)
PostPosted: Wed Apr 22, 2020 9:04 am  (#6)
Very nice, realistic!
PostPosted: Sat May 23, 2020 10:00 pm  (#7)
Before n After
PostPosted: Sun May 24, 2020 12:40 am  (#8)
Tony Sketch n Tony Ink
PostPosted: Sun May 24, 2020 12:45 am  (#9)
There is a way,
that I've found to do this.
These are the 4 steps that can be used.
1. Duplcate image 2 times.
2. Top image: Reduce saturation to -100,
Set layer mode to saturation.
3. Middle Image: Set layer mode to dodge.
Invert color, Gaussian Blur image (image size determins the amount of blur)
More for large image and less for small images.
4. Bottom Layer: Adjust color levers to the desired levels.
PostPosted: Sun May 24, 2020 1:32 am  (#10)
Here is another approach using Tin Tran's python plug-in 'Picture to Line Art'.
PostPosted: Sun May 24, 2020 2:26 am  (#11)
You also can try explore gmic plugin hard sketch
PostPosted: Sun May 24, 2020 2:32 am  (#12)
http://gimpchat.com/viewtopic.php?f=23&t=5948&start=0
Pencil sketch tutorial
PostPosted: Sun May 24, 2020 6:20 am  (#13)
model sponsor by generated.photo
PostPosted: Sun May 24, 2020 8:55 am  (#14)
Wallace, thanks for your workflow. The attached adds a color pencil effect by reducing the saturation layer opacity to zero.
Pexels by Ekaterina Bolovtsova  + WALLACE workflow + Saturation layer opacity = zero.jpg
Pexels by Ekaterina Bolovtsova + WALLACE workflow + Saturation layer opacity = zero.jpg [ 248.82 KiB | Viewed 3743 times ]
PostPosted: Sun May 24, 2020 11:24 pm  (#15)
Final Touch Gmic engrave color
