It is currently Thu Nov 19, 2026 9:19 am
 Post subject: Color Skething with Tone Map and G'mic Filters
PostPosted: Wed May 13, 2020 11:18 am  (#1)
Starting with couple quickies. Tutorial is in the tutorials section if you're interested.
Regular method, follows the tut almost precisely.
Another play.
Pexels-photo-of-woman-holding-wine-glass-2251185.jpg [ 777.17 KiB | Viewed 3885 times ]
One more.
pexels-woman-in-red-long-sleeve-shirt-holding-pen-3772511.jpg [ 672.78 KiB | Viewed 3885 times ]
 Post subject: Re: Color Skething with Tone Map and G'mic Filters
PostPosted: Wed May 13, 2020 12:17 pm  (#2)
They look nice !
PostPosted: Wed May 13, 2020 1:37 pm  (#3)
Thank you for compliment Dinasset.
Same image survived both methods. Original from pexels by JJ Jordan.
Method 1.
Pexels-woman-in-brown-and-red-long-dress-3087907-method1.jpg [ 846.34 KiB | Viewed 3862 times ]
Method 2.
pexels-woman-in-brown-and-red-long-dress-3087907-method2.jpg [ 807 KiB | Viewed 3862 times ]
PostPosted: Thu May 14, 2020 9:39 pm  (#4)
Very effective sketches Nidhogg :kpix Thank you for the tutorial going to try it over the weekend :tyspin
PostPosted: Fri May 15, 2020 6:12 am  (#5)
Thank Nidhogg
I tried but I will have to start again with other images ....because it's not terrible(always level 0) :gaah
with this image:
method 1:
alternative method:
PostPosted: Fri May 15, 2020 6:52 am  (#6)
Thanks much for trying level_0. :jumpclap
It can be little difficult to get good working values at first.
I found that decreasing the amplitude and raising edge in the felt pen settings helps, but I change them settings on every image.
You can also try different merging option in the Graphics Boost step, that gives lighter result than Colors Doping.
The second method with Stress Tone Map works only well with certain images.
Tried with same image, this wasn't done exactly like in tutorial.
After Bilateral Smooth, I changed the layer mode to addition, created new layer from visible and applied the felt pen on that layer.
Got to test more with nature images...
Building from pexels.
pexels-red-concrete-building-through-black-metal-gates-opened-2606600.jpg [ 1000.79 KiB | Viewed 3785 times ]
I've played with this one earlier.
PostPosted: Fri May 15, 2020 12:46 pm  (#7)
I like these last 2. :clap
One more try:
PostPosted: Fri May 15, 2020 2:55 pm  (#8)
That looks nice! I knew you'd get the hang of it quickly, must be from Venice?
So I browsed Venice photos at Pexels.
PostPosted: Fri May 15, 2020 11:45 pm  (#9)
Nidhogg :wvy
superb outcome
The accentuation of the black lines makes me think of the painter Buffet.
PostPosted: Sat May 16, 2020 2:42 am  (#10)
How interesting your results and research, Nidhogg. I really like your results a lot. I'll try to follow your tutorial and thanks for your time to write it and share it. :tyspin
PostPosted: Sat May 16, 2020 7:49 am  (#11)
Thank you Issabella. If you try it, read my comment in the 6th post how I changed the workflow just a little after writing the tut.
It's simpler and the colors will look better.
level_0, had to check Bernard Buffet out, he's new to me. You have so many famous painters.
Never gone very deep into the real art world, but I have London Academy Editions of Cézanne, Matisse & Gauguin.
And a drawing/illustration package that I got as a gift years ago and it is still unopened...
Link to original
https://www.pexels.com/photo/architectu ... y-2675269/
Graphic Boost Colors Doping option.
pexels-architectural-design-architecture-carrossel-city-2675269-Colors-Doping.jpg [ 992.77 KiB | Viewed 2899 times ]
Graphic Boost Comix Colors option.
pexels-architectural-design-architecture-carrossel-city-2675269-Comix-Colors.jpg [ 998.4 KiB | Viewed 2899 times ]
PostPosted: Sat May 16, 2020 9:43 am  (#12)
Bernard Buffet: https://www.estades.com/shop/bernard-buffet/
I can't see which of the images below is the best ?
PostPosted: Sat May 16, 2020 10:06 am  (#13)
Nidhogg,a third, I started again using your remark for "addition":
PostPosted: Sat May 16, 2020 11:20 am  (#14)
Looking good level_0. I like the 2nd because it has little more black sketching, that's just my preference.
You can see that I enjoy rough dirty style.
These were the felt pen settings I used on this castle.
[G'MIC] Felt Pen: fx_feltpen 52,41.6,0.16,0.308,14.5,3,0,50,50
PostPosted: Sat May 16, 2020 1:42 pm  (#15)
Nidhogg, in step 2 (Filter:Colors / Exposure) of the tutorial I don't see any modification of the images with Black Level = -0.001? Is this the right number? ;)
PostPosted: Sat May 16, 2020 2:21 pm  (#16)
Yes. It is simply a fix step to make 100% black pixels 99.99% black
If you try the next step with image that has lot of #000000 pixels you will see the problem.
It's possible to use another tone mapping filter but I like Fattal.
