It is currently Thu Nov 19, 2026 9:17 am
 Post subject: GT BEVEL
PostPosted: Wed May 13, 2020 2:19 pm  (#1)
I want to get the above but get the comment below
what went wrong, I have to go to ambient light 0.45 but that is not possible with the new gimp2.10
does anyone know what i can do,Thanks in advance
 Post subject: Re: GT BEVEL
PostPosted: Wed May 13, 2020 5:10 pm  (#2)
Hi Gimper. Do you have the updated version for 2.10? If not Here is the script for 2.10
gt-bevel-updt.scm [8.46 KiB]
Downloaded 158 times
PostPosted: Thu May 14, 2020 3:55 am  (#3)
pocholo,thanks for the update, i installed it and it works perfectly.
I made a wall patern as you can see at the top,thanks again pocholo
brick wall6.pat [256.03 KiB]
PostPosted: Thu May 14, 2020 2:23 pm  (#4)
Nice work on the brick texture. I went ahead and edited it for textured mortar and used a bumpmap to give it more dept similar to 3-D.
Brick-wall-3D.pat [256.04 KiB]
Downloaded 187 times
PostPosted: Thu May 14, 2020 6:57 pm  (#5)
Where did you find the tutorial? It seem one of conbagui tutorial from deviantart. He have a lot of good tutorial and I'm using them to create my scripts. You should give him credit.
