It is currently Thu Nov 19, 2026 9:22 am
 Post subject: Something Osteospermum to play with
PostPosted: Tue Jun 02, 2020 5:29 am  (#1)
Something from the garden this time:
Kevin
 Post subject: Re: Something Osteospermum to play with
PostPosted: Tue Jun 02, 2020 3:29 pm  (#2)
Weird accident using G'mic Colored Pencils.
PostPosted: Wed Jun 03, 2020 7:20 am  (#3)
PostPosted: Wed Jun 03, 2020 8:16 am  (#4)
Beautiful flower to begin with, Kevin. Nidhogg and Skinnyhouse, great ideas for transformation of the image!
PostPosted: Wed Jun 03, 2020 9:50 am  (#5)
My play.
2020-06-03 16-45-52 IMGP7922, using patterns set=FPSspot09, 18 colours.png [ 4.29 MiB | Viewed 3198 times ]
PostPosted: Wed Jun 03, 2020 5:37 pm  (#6)
UserFilter+G'mic = :
PostPosted: Thu Jun 04, 2020 2:09 am  (#7)
MareroQ, beautiful image! Which filter did you use?
PostPosted: Thu Jun 04, 2020 2:41 am  (#8)
Thought I would join the flower show contributors ... BRL with a glossy e-map and then difference blend mode + some soft light too.
PostPosted: Thu Jun 04, 2020 8:23 am  (#9)
PostPosted: Fri Jun 05, 2020 2:40 am  (#10)
PostPosted: Fri Jun 05, 2020 2:47 am  (#11)
Ella - beautiful, soft and warm interpretation - love it :hi5
PostPosted: Fri Jun 05, 2020 3:03 am  (#12)
Thank you, oldmangrumpy.
I made a blurred pastel BG, desaturated the flower, mode > grain merge and did a bump map with the edges of the flower.
PostPosted: Fri Jun 05, 2020 4:26 am  (#13)
:wvy
