It is currently Thu Nov 19, 2026 11:53 am
 Post subject: Gimp really bugs me
PostPosted: Fri May 27, 2011 9:48 pm  (#1)
in a cool sorta way. :)
XCF attached which includes all paths for legs, highlights, and wing separation lines.
bug.xcf [281.26 KiB]
Downloaded 99 times
 Post subject: Re: Gimp really bugs me
PostPosted: Fri May 27, 2011 9:52 pm  (#2)
Excellent vexel Rod. :)
PostPosted: Fri May 27, 2011 9:54 pm  (#3)
Thanks Lyle.
Another with GN applied from GMIC. :)
PostPosted: Fri May 27, 2011 9:56 pm  (#4)
Probably should have shrunk it down and got rid of the jaggies though. :)
PostPosted: Fri May 27, 2011 9:59 pm  (#5)
Here we go i selected it all shrank by 2 and feathered it.Then i used unsharp mask. :)
I really love the graphic Novel filter for things like this.
PostPosted: Fri May 27, 2011 10:25 pm  (#6)
Hope you don't mind a little play with your bug Rod. Used Inkscape Material (marble) filter and a bunch of various GIMPy blends for this result. :)
PostPosted: Fri May 27, 2011 10:33 pm  (#7)
I do not mind at all use it for whatever purposes under the sun. :)
I like all the newer materials with Inkscape 048.
In fact the idea from this bug comes from an Inkscape tutorial on YouTube.
I wish the interpolate filter ran on text still though.Seems like the newer 48 version lost a few tricks.
Trying to create a SWF through Inkscape today and realized it.Shapes work fine with styles even.But text will no longer interpolate like in 046. :\
PostPosted: Fri May 27, 2011 10:36 pm  (#8)
Now all we need is an Open Source program so it can be its mascot. :)
PostPosted: Fri May 27, 2011 10:49 pm  (#9)
Here is something really cool.I ran it with trace bitmap under Inkscape with 12 colors and got a neat abdomen effect on the bugs body. :)
PostPosted: Fri May 27, 2011 11:55 pm  (#10)
you guys have really got me thinking of trying Inkscape...I've had it for a while but never used it...seems from reading what you all have written about it iover the past few weeks that it might not be too difficult to use but I'd like to know some basic differences between Inkscape and GIMP and what sort of situations you might use it in. Also, is it a first cousin of GIMP or just another graphic imaging program???
PostPosted: Sat May 28, 2011 12:28 am  (#11)
Hey akky; Inkscape is primary a vector editor (unlike GIMP which is a raster bitmap editor). Inkscape does have filter that can work with both bitmap and vector input (such as the marble filter I used here). There is a synergistic relationship between GIMP and Inkscape and many, including me, wish they would just combine the two into a higher lever program. You can try to use Shellout if you want to transfer a bitmap into Inkscape, but in order to get something in return, you have to export (not save) the bitmap file prior to exiting it. I just run it as a separate program and transfer my result back into GIMP via drag/drop. :)
PostPosted: Sat May 28, 2011 12:40 am  (#12)
ok can you explain the difference between vector, raster and anything else related because its always been a bit of a mystery to me and I see people asking that question around the net...I have no idea myself
PostPosted: Sat May 28, 2011 12:58 am  (#13)
A vector is an image represented by coordinates and the program or viewer used turns those coordinates into an image. A bitmap is a pixel by pixel representation of an image (no coordinates or math at all). Vectors can give you higher quality images and is scaleable since the image you see is being rendered by the editor or viewer using it's built in rasterizer capabilities. Bitmaps don't have this capability so if you have to scale a bitmap, you can get stair-stepping and other aliasing issues. Bitmaps like photos though really can't be vectorized without looking like some type of pop art or taking huge amounts of memory since photo quality is very subjective in order to look right, that is where a bitmap editor such as GIMP is really needed. Each system has it's advantages and disadvantages depending on what you want to do. I pretty much mainly do bitmap editing and fake the vector using vexel approximations most of the time (a vexel is the bitmap representation of a vector; it is not scaleable as a vector model would be). Now someone here can correct me or add more to my diatribe if they so choose. lol
PostPosted: Sat May 28, 2011 1:26 am  (#14)
ok well I am not sure that I completely understand but its a start. Thank you Lyle. :)
PostPosted: Sat May 28, 2011 1:44 am  (#15)
I made that one too in inkscape. it was fun. I don't have it on my laptop so I can't post it.
PostPosted: Sat May 28, 2011 1:56 am  (#16)
Hey Akky; another name for a Rasterizer is a Raster Image Processor or RIP. lol
One of the ones that I like to do w.r.t. printing is Ghostscript/Ghostview since I can also create PDFs using it. :)
PostPosted: Sat May 28, 2011 6:52 am  (#17)
RIP ?
No thank i don't want a RIP ,no yet !
