It is currently Thu Nov 19, 2026 8:42 am
 Post subject: Psychedelic manips using G'MIC Diffusion Tensors
PostPosted: Mon Jul 13, 2020 7:47 am  (#1)
The photo layer is duplicated then G'MIC Artistic/Diffusion Tensors is run on the top layer. The top layer is then put into a layer mode.
For this one, I used Difference mode then adjusted levels on the bottom layer.
For this one, I used Grain Merge mode then reduced the opacity of the top layer.
 Post subject: Re: Psychedelic manips using G'MIC Diffusion Tensors
PostPosted: Mon Jul 13, 2020 9:11 am  (#2)
Sort of has a stain glass appeal, Erisian. Like the colorful results. :)
