It is currently Thu Nov 19, 2026 8:41 am
 Post subject: Another Mosaic?
PostPosted: Wed Jul 15, 2020 8:39 am  (#1)
For this I just used GMIC Super Pixels (default) then Filter > light and shadow > lighting effects > bumpmap
 Post subject: Re: Another Mosaic?
PostPosted: Wed Jul 15, 2020 12:10 pm  (#2)
Interesting that the mosaic pieces around the teeth, actually look like teeth. Maybe she needs braces. :)
Speaking of which, amazing what they can do with braces: https://giphy.com/gifs/TPFsF6Gxu2cM0
PostPosted: Wed Jul 15, 2020 1:35 pm  (#3)
Interesting sallyanne, a variation of your method.
Ran the Super Pixels 3 times using same settings.
It gives sort of a broken look.
Then Morphological Operation Erosion 3x3 to get thicker lines.
Bump Map, type spherical and played little with the other settings.
PostPosted: Wed Jul 15, 2020 1:41 pm  (#4)
Cool Nidhogg, I knew there had to be something there to do it manually that was easy. I tried it as well (later) with smaller super pixels but it didnt make any difference to her teeth. I guess it follows the colours ;)
