It is currently Thu Nov 19, 2026 8:43 am
 Post subject: Sun Burst Art
PostPosted: Fri Jul 24, 2020 10:50 am  (#1)
ef
 Post subject: Re: Sun Burst Art
PostPosted: Fri Jul 24, 2020 12:25 pm  (#2)
gg
PostPosted: Fri Jul 24, 2020 1:17 pm  (#3)
Good work. :jumpclap Have a tutorial?
PostPosted: Fri Jul 24, 2020 9:47 pm  (#4)
bh
PostPosted: Fri Jul 24, 2020 10:15 pm  (#5)
These are great! :)
PostPosted: Fri Jul 24, 2020 11:47 pm  (#6)
Look nice. :)
Not sure this is that widely known, but convert selection to path and back to selection, then fill with color again, makes the edges less "pixelated". Doesn't always work well on smaller/thinner objects though, which have a tendency to magically disappear. :)
PostPosted: Sat Jul 25, 2020 4:41 pm  (#7)
Qruqs wrote:
Look nice. :)
http://gimpchat.com/viewtopic.php?f=23&t=4883&hilit=pixellation
PostPosted: Sun Jul 26, 2020 1:07 am  (#8)
Oh. Well, I re-discovered it on my own. :)
PostPosted: Sun Jul 26, 2020 3:47 am  (#9)
Possibly worth mentioning the sun-burst rays.
In Gimp 2.8 one way was the line-nova script. This is missing from Gimp 2.10 menu structure but at the moment is still there if you use the search / (forward-slash) key example: https://i.imgur.com/teCg47D.jpg
An alternative again from Gimp 2.8 days was a sunray script, a bit more flexible than line-nova and a bit more hands on. It makes a selection, up-to-you to fill it. (or use it to cut out). Script attached, example: https://i.imgur.com/BnpfnnO.jpg Registers in a strange place Tools -> Selection Tools -> SunRay Pattern.
...and much more recent. The gmic plugin: https://i.imgur.com/T4DhH3Z.jpg
sunray.scm [4.73 KiB]
Downloaded 149 times
