It is currently Thu Nov 19, 2026 7:50 am
Post new topic Reply to topic  [ 133 posts ]  Go to page 1, 2, 3, 4, 5 ... 7  Next
 Post subject: experimenting on drawing effects: style C
PostPosted: Sun Sep 13, 2020 12:29 am  (#1)
Time to initiate a new drawing experiment.
Based on G'mic tensors.
Images from Deviant Art.
2020-09-13 07-21-17elven_fairy_by_lucreciamortishia_ddw62nm-fullview, with a draw effect style C (GEGL desat C2G) (resolution=9.6) (size=4.8) (skin enhanced).jpg
2020-09-13 07-21-17elven_fairy_by_lucreciamortishia_ddw62nm-fullview, with a draw effect style C (GEGL desat C2G) (resolution=9.6) (size=4.8) (skin enhanced).jpg [ 731.73 KiB | Viewed 12788 times ]
2020-09-13 07-23-33october_sisters_by_lucreciamortishia_de50684-pre, with a draw effect style C (GEGL desat C2G) (resolution=9.6) (size=4.8) (skin enhanced).jpg
2020-09-13 07-23-33october_sisters_by_lucreciamortishia_de50684-pre, with a draw effect style C (GEGL desat C2G) (resolution=9.6) (size=4.8) (skin enhanced).jpg [ 309.8 KiB | Viewed 12788 times ]
2020-09-13 07-24-53de1d09y-0239e8cb-d645-48d0-9681-01577732b26f, with a draw effect style C (GEGL desat C2G) (resolution=9.6) (size=4.8).jpg
2020-09-13 07-24-53de1d09y-0239e8cb-d645-48d0-9681-01577732b26f, with a draw effect style C (GEGL desat C2G) (resolution=9.6) (size=4.8).jpg [ 575.22 KiB | Viewed 12788 times ]
 Post subject: Re: experimenting on drawing effects: style C
PostPosted: Sun Sep 13, 2020 8:32 am  (#2)
I really like the last one with the canoes.
PostPosted: Sun Sep 13, 2020 8:35 am  (#3)
Nice
PostPosted: Sun Sep 13, 2020 9:37 am  (#4)
Thanks Mahvin & Sallyanne.
Yes, on people has to be improved (or just reserved to non-people images...).
PostPosted: Sun Sep 13, 2020 11:46 pm  (#5)
I really think the one with canoes is beautiful. Colors are brilliant. I do not favor the effect on skin.
PostPosted: Mon Sep 14, 2020 1:56 am  (#6)
Pat, glad to see you again a bit more active. Good news.
Thanks for your comment.
Yes, you agree with Mahvin and Sallyanne.
Because the initial flow of the procedure was paying more or less a "mixed" attention both to people and not people, the results are somehow a bit ambiguous.
This morning I decided to concentrate only on not people.
Results for those images are stronger now.
Later on I will try to dedicate more attention to people images.
PostPosted: Mon Sep 14, 2020 1:59 am  (#7)
Outcomes obtained with the new "preset" dedicated only to non-people images.
Source images from Deviant Art.
Two flower images:
2020-09-14 08-46-31top_of_the_flower_by_britt_pixs_de516ck-pre, with a draw effect style C (GEGL desat C2G) (resolution=20) (size=16).jpeg
2020-09-14 08-46-31top_of_the_flower_by_britt_pixs_de516ck-pre, with a draw effect style C (GEGL desat C2G) (resolution=20) (size=16).jpeg [ 433.11 KiB | Viewed 12674 times ]
2020-09-14 08-47-14flower____by_a_separate_reality_de514ok-pre, with a draw effect style C (GEGL desat C2G) (resolution=20) (size=16).jpeg
2020-09-14 08-47-14flower____by_a_separate_reality_de514ok-pre, with a draw effect style C (GEGL desat C2G) (resolution=20) (size=16).jpeg [ 453.2 KiB | Viewed 12674 times ]
One rocks image:
2020-09-14 08-48-16_dsc0013_by_nielsphoto_de51pik-fullview, with a draw effect style C (GEGL desat C2G) (resolution=20) (size=16).jpeg
2020-09-14 08-48-16_dsc0013_by_nielsphoto_de51pik-fullview, with a draw effect style C (GEGL desat C2G) (resolution=20) (size=16).jpeg [ 827.49 KiB | Viewed 12674 times ]
How do you evaluate these?
PostPosted: Mon Sep 14, 2020 2:08 am  (#8)
The same 3 images with one step in the processing modified.
2020-09-14 09-03-47top_of_the_flower_by_britt_pixs_de516ck-pre, with a draw effect style C (GEGL desat C2G) (resolution=20) (size=16).jpeg
2020-09-14 09-03-47top_of_the_flower_by_britt_pixs_de516ck-pre, with a draw effect style C (GEGL desat C2G) (resolution=20) (size=16).jpeg [ 436.27 KiB | Viewed 12673 times ]
2020-09-14 09-04-10flower____by_a_separate_reality_de514ok-pre, with a draw effect style C (GEGL desat C2G) (resolution=20) (size=16).jpeg
2020-09-14 09-04-10flower____by_a_separate_reality_de514ok-pre, with a draw effect style C (GEGL desat C2G) (resolution=20) (size=16).jpeg [ 461.91 KiB | Viewed 12673 times ]
2020-09-14 09-04-31_dsc0013_by_nielsphoto_de51pik-fullview, with a draw effect style C (GEGL desat C2G) (resolution=20) (size=16).jpeg
2020-09-14 09-04-31_dsc0013_by_nielsphoto_de51pik-fullview, with a draw effect style C (GEGL desat C2G) (resolution=20) (size=16).jpeg [ 887.37 KiB | Viewed 12673 times ]
Personally, I like them better, and you?
PostPosted: Mon Sep 14, 2020 3:04 am  (#9)
First attempt on the new processing specific for a portrait.
Source image Pexels.
2020-09-14 10-00-35pexels-photo-1878522, with a draw effect style C (GEGL desat C2G) (resolution=10) (size=5) (skin enhanced).jpeg
2020-09-14 10-00-35pexels-photo-1878522, with a draw effect style C (GEGL desat C2G) (resolution=10) (size=5) (skin enhanced).jpeg [ 110.26 KiB | Viewed 12668 times ]
PostPosted: Mon Sep 14, 2020 3:14 am  (#10)
Re-using the first portrait on the thread (D.A.).
2020-09-14 10-13-07elven_fairy_by_lucreciamortishia_ddw62nm-fullview, with a draw effect style C (GEGL desat C2G) (resolution=10) (size=5) (skin enhanced).jpeg
2020-09-14 10-13-07elven_fairy_by_lucreciamortishia_ddw62nm-fullview, with a draw effect style C (GEGL desat C2G) (resolution=10) (size=5) (skin enhanced).jpeg [ 611.21 KiB | Viewed 12668 times ]
PostPosted: Mon Sep 14, 2020 10:36 am  (#11)
Back to Mountains.
Image from D.A.
2020-09-14 17-32-31de54a2g-6992fd4f-b9dd-4f49-a1ab-93f4aa88ce16, with a draw effect style C (GEGL desat C2G) (resolution=20) (size=16).jpeg
2020-09-14 17-32-31de54a2g-6992fd4f-b9dd-4f49-a1ab-93f4aa88ce16, with a draw effect style C (GEGL desat C2G) (resolution=20) (size=16).jpeg [ 222.61 KiB | Viewed 2730 times ]
PostPosted: Mon Sep 14, 2020 10:39 am  (#12)
Landscape (from D.A.)
2020-09-14 17-38-09morning_at_the_countryside_by_roisabborrar_de549w8-fullview, with a draw effect style C (resolution=20) (size=16).jpeg
2020-09-14 17-38-09morning_at_the_countryside_by_roisabborrar_de549w8-fullview, with a draw effect style C (resolution=20) (size=16).jpeg [ 472.08 KiB | Viewed 2731 times ]
PostPosted: Mon Sep 14, 2020 10:42 am  (#13)
Mountains again (D.A.).
2020-09-14 17-40-41road_by_dashakern_de54hux-fullview, with a draw effect style C (resolution=20) (size=16).jpeg
2020-09-14 17-40-41road_by_dashakern_de54hux-fullview, with a draw effect style C (resolution=20) (size=16).jpeg [ 421.91 KiB | Viewed 2732 times ]
PostPosted: Mon Sep 14, 2020 10:44 am  (#14)
Rocks (D.A.)
2020-09-14 17-43-26boulders_of_dwarfs_by_citizenfresh_de547in-pre, with a draw effect style C (resolution=20) (size=16).jpeg
2020-09-14 17-43-26boulders_of_dwarfs_by_citizenfresh_de547in-pre, with a draw effect style C (resolution=20) (size=16).jpeg [ 473.61 KiB | Viewed 2732 times ]
PostPosted: Mon Sep 14, 2020 10:49 am  (#15)
A honey bee, close-up (D.A.)
2020-09-14 17-45-44wee_honey_bee_by_snomanda_de50kw5-fullview, with a draw effect style C (resolution=20) (size=16).jpeg
2020-09-14 17-45-44wee_honey_bee_by_snomanda_de50kw5-fullview, with a draw effect style C (resolution=20) (size=16).jpeg [ 668.75 KiB | Viewed 2731 times ]
PostPosted: Mon Sep 14, 2020 10:52 am  (#16)
Ducklings (D.A.).
2020-09-14 17-50-48mallard_with_ducklings_by_oliverbphotography_de4vy4u-pre, with a draw effect style C (resolution=20) (size=16).jpeg
2020-09-14 17-50-48mallard_with_ducklings_by_oliverbphotography_de4vy4u-pre, with a draw effect style C (resolution=20) (size=16).jpeg [ 477.85 KiB | Viewed 2731 times ]
PostPosted: Mon Sep 14, 2020 11:49 pm  (#17)
15th of September: some modifications in the steps.
3 landscapes from Deviant Art :
2020-09-15 06-25-35bendy_canyon_pano_by_jonathanjessup_de1gtd0-pre, with a draw effect style C (resolution=20) (size=16).jpeg
2020-09-15 06-25-35bendy_canyon_pano_by_jonathanjessup_de1gtd0-pre, with a draw effect style C (resolution=20) (size=16).jpeg [ 411.85 KiB | Viewed 2713 times ]
2020-09-15 06-26-21temporal_by_jonathanjessup_ddnwmk3-pre, with a draw effect style C (resolution=20) (size=16).jpeg
2020-09-15 06-26-21temporal_by_jonathanjessup_ddnwmk3-pre, with a draw effect style C (resolution=20) (size=16).jpeg [ 352.19 KiB | Viewed 2713 times ]
2020-09-15 06-27-05winter_spirit_by_jonathanjessup_ddzwwof-pre (1), with a draw effect style C (resolution=20) (size=16).jpeg
2020-09-15 06-27-05winter_spirit_by_jonathanjessup_ddzwwof-pre (1), with a draw effect style C (resolution=20) (size=16).jpeg [ 349.44 KiB | Viewed 2713 times ]
PostPosted: Mon Sep 14, 2020 11:51 pm  (#18)
3 portraits from Pexels:
2020-09-15 06-39-08pexels-photo-641314, with a draw effect style C (resolution=10) (size=5) (skin enhanced).jpeg
2020-09-15 06-39-08pexels-photo-641314, with a draw effect style C (resolution=10) (size=5) (skin enhanced).jpeg [ 57.61 KiB | Viewed 2713 times ]
2020-09-15 06-40-09pexels-photo-636736, with a draw effect style C (resolution=10) (size=5) (skin enhanced).jpeg
2020-09-15 06-40-09pexels-photo-636736, with a draw effect style C (resolution=10) (size=5) (skin enhanced).jpeg [ 128.34 KiB | Viewed 2713 times ]
2020-09-15 06-41-06pexels-photo-1559193, with a draw effect style C (resolution=10) (size=5) (skin enhanced).jpeg
2020-09-15 06-41-06pexels-photo-1559193, with a draw effect style C (resolution=10) (size=5) (skin enhanced).jpeg [ 128.99 KiB | Viewed 2713 times ]
PostPosted: Mon Sep 14, 2020 11:58 pm  (#19)
3 animals from Pixabay:
2020-09-15 06-54-50lioness-5564911_960_720, with a draw effect style C (resolution=20) (size=16).jpeg
2020-09-15 06-54-50lioness-5564911_960_720, with a draw effect style C (resolution=20) (size=16).jpeg [ 263.82 KiB | Viewed 2712 times ]
2020-09-15 06-55-12alpaca-5564306_960_720, with a draw effect style C (resolution=20) (size=16).jpeg
2020-09-15 06-55-12alpaca-5564306_960_720, with a draw effect style C (resolution=20) (size=16).jpeg [ 264.29 KiB | Viewed 2712 times ]
2020-09-15 06-55-34cat-5560248_960_720, with a draw effect style C (resolution=20) (size=16).jpeg
2020-09-15 06-55-34cat-5560248_960_720, with a draw effect style C (resolution=20) (size=16).jpeg [ 242.59 KiB | Viewed 2712 times ]
PostPosted: Tue Sep 15, 2020 12:08 am  (#20)
3 flowers from Clean Public Domain:
2020-09-15 07-03-03flower-3167499-1560x1170, with a draw effect style C (resolution=20) (size=16).jpeg
2020-09-15 07-03-03flower-3167499-1560x1170, with a draw effect style C (resolution=20) (size=16).jpeg [ 689.96 KiB | Viewed 2712 times ]
2020-09-15 07-04-24flower-2984757-1560x1040, with a draw effect style C (resolution=20) (size=16).jpeg
2020-09-15 07-04-24flower-2984757-1560x1040, with a draw effect style C (resolution=20) (size=16).jpeg [ 566.53 KiB | Viewed 2712 times ]
2020-09-15 07-05-50rose-1732782-1560x1040, with a draw effect style C (resolution=20) (size=16).jpeg
2020-09-15 07-05-50rose-1732782-1560x1040, with a draw effect style C (resolution=20) (size=16).jpeg [ 607.81 KiB | Viewed 2712 times ]
