Here is my first experiment using One by Wacom purchased 2 weeks ago.
First I tried Superhero character called Tony Toaster,
but realized soon it would be way too hard to begin with a human figure.
But he shall be done later, because the idea was super goofy. He's got massive toaster hands
made of vibranium-graphene compound that work like hammers against the villains.
One of the special moves is to flat the enemy between the toasters, put him in and eject into outer space
For the good and the poor he's shooting free bread.
He also carries a ferminator back pack where he collects waste and street thrash
to create electricity for the toasters.
So I was pondering what to draw.
This Monday I had to re-create family coat of arms for one client because the original was so bad.
It had a tree in the middle of shield, and that seemed like easy enough opening subject.
First I drew the black edges on one layer,
then all the coloring was done on another layer.
Brush 2 Hardness 075, size 3-4px and eraser were the only tools used.
Guess around 6 hours spent, the leaves worked like a practice to see how hand works.
The inability to rotate canvas seems to be no problem, but I don't rotate real paper either. Do you?
Looks a bit dead, maybe I have guts for animal or something more challenging next time.
See ya, it's storming here in Finland!
