It is currently Thu Nov 19, 2026 8:39 am
 Post subject: Image Layer Disappears When I Move It
PostPosted: Tue Oct 06, 2020 7:41 am  (#1)
So, on all types of layers if i click it with the move tool :move it goes invisible. i can move it around turn it whatever as if it's still there, and it shows the outside box so ik how big/where it is. However it's extremely annoying :gaah bc it's not a perfect outline of what i've drawn/the image i imported just a box around the object. Also every time i move a layer it goes down in quality becoming more and more burly every time i move it! Please let me know if you have any fixes for either of these problems. Thank You Bunches :heart
 Post subject: Re: Image Layer Disappears When I Move It
PostPosted: Tue Oct 06, 2020 11:42 am  (#2)
Screenshot?
PostPosted: Tue Oct 06, 2020 10:01 pm  (#3)
I actually went to go get screenshots and fixed it mostly, it doesn't happen when i use the move tool :move it only happens when i use "Unified Transform Tool". Idk if that's meant to happen, but it fixes my problem bc i don't need to use that tool. thx 4 ur time tho
also if it's not meant to happen idk how to add screenshot on here
PostPosted: Tue Oct 06, 2020 10:35 pm  (#4)
You can add a screenshot by attaching it in the provided box below where you post a reply. Until you have 5 posts you cannot upload it normally.
PostPosted: Wed Oct 07, 2020 3:13 am  (#5)
@ Re_FriedTofu
Tick the "show preview" button in tool options.
Unified Transform is a good tool, scale / rotate / move / ... etc all in one operation. This avoids multiple pixel interpolation between individual tools. However scaling up is the same everywhere. A big scale is a fuzzy scale. Use the best interpolation available, but do not expect great quality.
