It is currently Thu Nov 19, 2026 11:41 am
 Post subject: Gmic... a few Kuwahara Puff Fishes
PostPosted: Thu Jun 02, 2011 6:56 pm  (#1)
The idea was play with the new Gmic Kuwahara filter, i tought this Puffer Fish
http://en.wikipedia.org/wiki/File:Aroth ... Hawaii.jpg
would be good to test
The first results were promising...
pesce_000029 by PhotoComix_Mandala, on Flickr
 then why don't try to combine with one of the gmic edges filter ?
I mean create 2 duplicates , apply kuwahara to the first, an edge detection filter
well the only adapt apparently was the first filter of that list "Gradient norm" (used with "negative" option
but the result was sort of bleached...)
pesce_000016 by PhotoComix_Mandala, on Flickr
 But after correcting the level (using Automatic option ) was looking much better very close to this
Kuwahara Puff fish by PhotoComix_Mandala, on Flickr
NOW THE REAL FUN THE COMBINATIONS:
image 1 & 3 (or 1 & 2 ) merged with different layer modes
Multiply
pesce_000033 by PhotoComix_Mandala, on Flickr
pesce_000021 by PhotoComix_Mandala, on Flickr
pesce_000015 by PhotoComix_Mandala, on Flickr
pesce_000012 by PhotoComix_Mandala, on Flickr
Here the Kuwahara effect is less visible but the combination still nice ( lightness may be corrected )
DFFERENCE MODE looks as a negative...will create a nice positive ?
pesce_000009 by PhotoComix_Mandala, on Flickr
...YES !!
pesce_000010 by PhotoComix_Mandala, on Flickr
The darkest (i believe Burn mode)
pesce_000008 by PhotoComix_Mandala, on Flickr
BW (now not sure if was value or saturation mode )
pesce_000007 by PhotoComix_Mandala, on Flickr
 no bad at all
but i saw that a additional passage with graphic give an extra kick,
for the test i just apply to all that layers Graphic novel with the default values with no adjustment of sort
See next message for the differences
PS only other edit...2 brushstroke on a transparent layer on top to ass 2 light reflex in the fish eyes, i could not resist doing
but i resisted to add Vamp's teeth
 Post subject: Re: Gmic... a few Kuwahara Puff Fishes
PostPosted: Thu Jun 02, 2011 7:09 pm  (#2)
Looks pretty good PC; wasnt' getting the same result as the gluas Kuwahara, but you first one really does look like what gluas would do. Also like your b/w outline version. :)
PostPosted: Thu Jun 02, 2011 7:17 pm  (#3)
I agree, Lyle. G'MIC and gluas aren't the same output. Gluas seems to have a little more spread than G'MIC does.
PC: Nice work, btw!
PostPosted: Thu Jun 02, 2011 7:29 pm  (#4)
Very Cool PC!
I'm back I think
PostPosted: Thu Jun 02, 2011 7:45 pm  (#5)
Lylejk , Willy , mahvin thank for the comments :hi5
I like much more after a additional passage with Gmic Graphic Novel
(i just used the default in batch for all )
This was multiply
This the Negative from Difference
a Zombi looking effect for fish skin... i like also what happened here to the BG
http://www.flickr.com/photos/photocomix ... otostream/
PostPosted: Thu Jun 02, 2011 7:53 pm  (#6)
I love that one with the cool background!
Your Zombie Fish has a cool background!
I'm back I think
PostPosted: Thu Jun 02, 2011 7:58 pm  (#7)
Those are very cool. I particularly like the second group you posted. :jumpclap :yes
PostPosted: Thu Jun 02, 2011 8:15 pm  (#8)
I like the puffer fish!! I think my fav is the multiply one. :)
Liana
PostPosted: Thu Jun 02, 2011 9:08 pm  (#9)
:wow Works well also with Amanda Tappping (Sanctuary) not only with tropical fishes !!
:spring
Not going to mix here Fish & Sanctary fan art but i will show soon... :wizwand
PostPosted: Thu Jun 02, 2011 9:14 pm  (#10)
Damn Gimp crashed when saving Amanda Tapping !! :gaah
PostPosted: Thu Jun 02, 2011 9:31 pm  (#11)
lol; I still liked her better at Stargate SG-1 though (but do like and watch Sanctuary too). :)
PostPosted: Fri Jun 03, 2011 4:32 am  (#12)
ohhh they do look pretty for puffer fish!! usually they are as ugly as sin! I saw one big puffer bite the blade off a fishing knife when we were trying to set it free...imagine what they do to your fingers...worst part about that was it actually swallowed the blade as well...glad I didnt see more.
well done PC but sorry to hear of your crash
PostPosted: Fri Jun 03, 2011 9:10 am  (#13)
Arothron_hispidus_Hawaii by cecilia fx, on Flickr
my experiment with mr fish
there's three layers here. One of which is kaleidescope of the duplicated fish layer which had to be scaled :scale after positioning it to be centered over the fishes face and still cover the right side of the image
the other top layer had some other effect the name of which i forgot because i was too excited to get it done :mrgreen:
PostPosted: Fri Jun 03, 2011 9:21 am  (#14)
i found Gmic and Gluas Kuwahara equivalent what changes is not the effect but the default, Gluas use more dramatic setting as default
Basically in gmic to get same effect
1 set iteration to 2
2 increase the "Radius"
and you will got a equivalent result (or at least very close ) THAT YOU MAY SAVE AS PRESET (Fav )
@Cecilia
interisting effect looks cool on the BG, expecially the lower half and on the fish skin (but no much sure for the orange shapes ) , it seems to create sort of algae..
