It is currently Thu Nov 19, 2026 7:46 am
 Post subject: Gmic
PostPosted: Fri Nov 13, 2020 1:41 pm  (#1)
can someone give me the link to gmic,and also the correct way to install Gmic.
thank you in advance,gimper66
 Post subject: Re: Gmic
PostPosted: Fri Nov 13, 2020 2:02 pm  (#2)
https://gmic.eu/download.html
1. Delete all the files associated with G'MIC before you install the updated version and you will not have any problem.
2. Use the installer version
3. Install the plugin in you GIMP user profile GIMP 2.10 plugins folder
PostPosted: Sat Nov 14, 2020 12:46 pm  (#3)
it was not for myself but it has been posted and works perfectly. thanks pocholo
