It is currently Thu Nov 19, 2026 7:45 am
 Post subject: drawing effects: style xxxx
PostPosted: Wed Dec 16, 2020 3:35 pm  (#1)
There are many posts about experimenting on drawing effects: style xxxx. What it is? Scripts, Plugins,extern Program like GMIC? How to start?
 Post subject: Re: drawing effects: style xxxx
PostPosted: Wed Dec 16, 2020 3:41 pm  (#2)
They are scripts by Dinasset. There should be links, perhaps in the resources scripts section.
PostPosted: Thu Dec 17, 2020 12:05 am  (#3)
So far you have:
viewtopic.php?f=9&t=18702&hilit=style
viewtopic.php?f=9&t=18735&hilit=style
viewtopic.php?f=9&t=18827&hilit=style
viewtopic.php?f=9&t=18808&hilit=style
viewtopic.php?f=9&t=18846&hilit=style
viewtopic.php?f=9&t=18986&hilit=style
viewtopic.php?f=9&t=18880&hilit=style
viewtopic.php?f=9&t=18909&hilit=style
viewtopic.php?f=9&t=18933&hilit=style
viewtopic.php?f=9&t=18968&hilit=style
all downloadable and usable
PostPosted: Thu Dec 17, 2020 4:37 am  (#4)
Now published also the last one for 2020:
viewtopic.php?f=9&t=18996
PostPosted: Thu Dec 17, 2020 12:19 pm  (#5)
THX. That helps a lot. Will check it next days
PostPosted: Fri Dec 18, 2020 11:31 am  (#6)
Nothing in Windows is so simple than it looks like. Scripts installed, Folder declared in /edit/settings/folder/scripts ...
As I understand script for style A there must be a submenue 'Diego' in Image. There is nothing. I checked all other folder as well. Possible to tell gimp showing errors until start?
PostPosted: Fri Dec 18, 2020 12:03 pm  (#7)
They are all python filter, hence not scripts, but plug-ins.
PostPosted: Sat Dec 19, 2020 2:38 am  (#8)
THX. It works. now
File comment: DateTimeOriginal 2010:08:08 05:27:10, Talibong, Leyte, Philippines
2020-12-19 08-24-20DSC_5465, with a draw effect style C (colour) (soft look) (medium texture).jpg
2020-12-19 08-24-20DSC_5465, with a draw effect style C (colour) (soft look) (medium texture).jpg [ 625.08 KiB | Viewed 2989 times ]
