It is currently Thu Nov 19, 2026 7:49 am
 Post subject: FX-FOUNDRY
PostPosted: Mon Jan 11, 2021 6:30 am  (#1)
i'm loocking for fx-foundry.
i would also like to know all the possibilities of the fx-foundry.
thanks in advance,gimper66
 Post subject: Re: FX-FOUNDRY
PostPosted: Mon Jan 11, 2021 8:17 am  (#2)
does it even still exist
PostPosted: Mon Jan 11, 2021 8:47 am  (#3)
As far as I know the last release was for Gimp 2.6 https://sourceforge.net/projects/gimpfx ... -2.6-1.zip 118 scripts. Do not expect many of these to work out-of-the-box
Many have be updated by Paul Sherman https://www.gimphelp.org/script210.html although the naming convention is different
example: jeschke-mats-and-frames.scm (from fxfoundry) is called 210_edges_mats-and-frames.scm
PostPosted: Mon Jan 11, 2021 10:54 am  (#4)
I have the 210_edges_mats-and-frames.scm downloaded and installed
thanks for the tip and the rapid response
:tyspin :tyspin
