It is currently Thu Nov 19, 2026 7:50 am
 Post subject: Stringy Chimp
PostPosted: Sat Feb 06, 2021 12:33 am  (#1)
ref: https://pixabay.com/photos/chimpanzee-m ... o-3707270/
Like the illustrative like result using this technique. :)
https://www.flickr.com/photos/163034485 ... 97/sizes/o
 Post subject: Re: Stringy Chimp
PostPosted: Sat Feb 06, 2021 12:36 am  (#2)
I'd be interested to know how long it would take to do this on a much larger scale. You got me thinking of an elephant photo for my daughter's birthday.
PostPosted: Sat Feb 06, 2021 12:51 am  (#3)
Lyle, really love this technique!
PostPosted: Sat Feb 06, 2021 1:16 am  (#4)
Appreciate the words.
Not sure, Mahvin. If you have a beefy enough PC, then I doubt much time at all. I set the stencil to b/w and also ran (duplicate layer of original) my engrave preset trying to match the line size with the string size of the stencil. I set to darken to create the b/w stencil which I fed into blend>shape average (located in my test folder; David was so kind to preserve this preset upon my request many years back and I use it often; he put it into my name's folder). I then did a bit of anti-aliasing cleanup work and other enhancements. :)
PostPosted: Mon Feb 08, 2021 1:03 am  (#5)
I don't know if I managed to get the same effect, but I tried to follow the tips given by lylejk in discuss.pixls.us/
Anyway, I really liked the result.
Thank you Lylejk! :bigthup
PostPosted: Mon Feb 08, 2021 7:37 am  (#6)
:wvy lylejk, it's great as usual. :clap Krikor :clap
lylejk,with the confinement periods imposed by the Covid, could you not redo tutorials as you did about 10 years ago? I am convinced that I would not be the only one to appreciate. :)
PostPosted: Mon Feb 08, 2021 8:32 am  (#7)
Hi level_0, thx by comment.
I can share the xcf with the sets used in G'MIC (which are shown in the name of the layers) applied in my attempts.
But I think that they do not reflect the steps used by lylejk, it is only an approximate attempt (or even that).
In this forum the maximum size for an attachment is 5 MB, so I posted xcf.zip on this link https://www.sendspace.com/file/5kmi45
PostPosted: Mon Feb 08, 2021 10:19 am  (#8)
Looks great, Krikor. To get longer threads if you will, you can play with the Anisotrophic settings. Below's mine (which I call fake smudge). :)
PostPosted: Mon Feb 08, 2021 10:23 am  (#9)
I still work 2 jobs, level_0. lololol
One's mission critical, and the other is a part-time retail job. Little time for fun. lol
PostPosted: Mon Feb 08, 2021 10:31 am  (#10)
lylejk,it's too bad for us!
PostPosted: Mon Feb 08, 2021 10:35 am  (#11)
OK; found your Gorilla at Pixabay (believe it's yours). I did remove the effect on the backgroun as you did. Using the Aniso settings mentioned above and setting the Stencil radius to 1 (and iterations set to half way point), below's the result. :)
ref: https://pixabay.com/photos/gorilla-silv ... al-448731/
PostPosted: Mon Feb 08, 2021 11:28 am  (#12)
Thanks for the settings Lyle. Will try this when have time the results are so cool.
Got only one job, but things are so busy I forgot to eat today!
PostPosted: Mon Feb 08, 2021 7:28 pm  (#13)
Lyle - What is good for chimps must be good for wombats - sort of used your 'pixls' instructions but did some other mods too. Thanks for your inspirational post!!
PostPosted: Mon Feb 08, 2021 11:29 pm  (#14)
Definitely should work for any marsupials, OMG. lol
