It is currently Thu Nov 19, 2026 7:51 am
 Post subject: PYTON-FU-CREATE-LAYER-MASK-FROM...
PostPosted: Thu Feb 11, 2021 8:00 am  (#1)
in a YouTube tutorial it is referred to, create- layer- mask- from ...
as seen in the example
as you can see in the example below
1-I do have the normal add layer mask etc ...
2-but create-layer-mask-from is not in my list ?
i have the latest new gimp 10.22
can someone provide me the create-layer-mask-from ... script
I think it would help me well as I regularly work with layer masks
thanks in advance, gimper66
 Post subject: Re: PYTON-FU-CREATE-LAYER-MASK-FROM...
PostPosted: Thu Feb 11, 2021 8:45 am  (#2)
I did google (actually DuckDuckGo)
I found this: https://www.deviantart.com/slybug/art/C ... -324277895
PostPosted: Thu Feb 11, 2021 10:16 am  (#3)
I've always had this and the layer via copy/cut by slybug because it's handy.
Attached.
create-layer-mask-from.py.zip [1.55 KiB]
Downloaded 209 times
PostPosted: Fri Feb 12, 2021 6:51 am  (#4)
paynekj & nidlog,Thanks for the quick response.
i installed it as you can see in the example, thanks again
gimper66
