It is currently Thu Nov 19, 2026 11:53 am
 Post subject: Tarzan Hut
PostPosted: Tue Jun 07, 2011 10:21 am  (#1)
Well the Disney version of the Tarzan hut
i really didn't plan to do this but is my favorite
I SUGGEST to click for FULL SIZE !! (is all about details,)
HKDL_TARZAN'S_TREEHOUSE_fave-000001 by PhotoComiX, on Flickr
instead this was the plan (again test and play with the idea of a double-Kuwahara effect )
double-kuwahara-b by PhotoComiX, on Flickr
and see if could be somehow smoothed
double-kuwahara-b-melted by PhotoComiX, on Flickr
doublekuwaharab-melted-b by PhotoComiX, on Flickr
how much may be "melted" without loosing comprensibilty ?
HKDL_TARZAN'S_TREEHOUSE_000012b by PhotoComiX, on Flickr
ORIGINAL
HKDL_TARZAN'S_TREEHOUSE by PhotoComiX, on Flickr
 Post subject: Re: Tarzan Hut
PostPosted: Tue Jun 07, 2011 10:39 am  (#2)
Cool job, PhotoComix. Makes me want to swing through trees holding onto vines. :hehe
PostPosted: Tue Jun 07, 2011 1:43 pm  (#3)
You know this may be a great filter for taking out edgy jaggy lines in text.
Many times ill create a 3-D text effect and need to smooth the outlines (especially after creating perspective) so i usually just stroke the text with white or another color, and blur.I wonder if selecting and using this filter would work better?
I will have to experiment on it. :)
PostPosted: Tue Jun 07, 2011 1:44 pm  (#4)
Hrmmm --- will the filter work on just a selection?Or do you have to use the whole layer?
PostPosted: Tue Jun 07, 2011 4:08 pm  (#5)
i think will work on a selection
Now i am looking to the Gmic def to found a command to convert float in integer ...no luck till now
PostPosted: Tue Jun 07, 2011 5:14 pm  (#6)
Nice photos PC. :) That hut looks really cool. It's hot here.
Liana
