It is currently Thu Nov 19, 2026 7:07 am
 Post subject: csh file [Solved]
PostPosted: Mon Jun 07, 2021 9:47 am  (#1)
can someone tell me what this csh file is and if we can use it in gimp,the file is from photoshop
thank you in advance
gedrentel.zip [2.1 KiB]
Downloaded 131 times
 Post subject: Re: csh file
PostPosted: Mon Jun 07, 2021 10:05 am  (#2)
It is a Photoshop Custom Shapes file. Everything I have read online says that it cannot be used in any other software. You might be able to download a demo copy of Photoshop, open the file and export it though.
PostPosted: Mon Jun 07, 2021 11:01 am  (#3)
Draws this shape...
PostPosted: Mon Jun 07, 2021 2:45 pm  (#4)
we solved it,opened it in photoshop and saved it in png transparant.
than I made a gimp brush out of that,and it works perfectly.
thanks everyone for the quick response,gimper66
