It is currently Thu Nov 19, 2026 11:53 am
 Post subject: Golf Ball Text
PostPosted: Wed Jun 08, 2011 10:20 pm  (#1)
Pretty easy, nothing special
 Post subject: Re: Golf Ball Text
PostPosted: Thu Jun 09, 2011 7:47 am  (#2)
It would be cool to know how to do this.
PostPosted: Thu Jun 09, 2011 8:40 am  (#3)
I thot so too. I was looking for a link. lol.... very nice...
PostPosted: Thu Jun 09, 2011 1:25 pm  (#4)
All i did was take an image of a golf ball and cut everything around the text, then added a bevel on the text to give it some more highlights and shadows
PostPosted: Thu Jun 09, 2011 2:46 pm  (#5)
Golf Ball Patterns have to exist somewhere!
Very nice Jacob!
I'm back I think
PostPosted: Thu Jun 09, 2011 3:36 pm  (#6)
Willy, go to Bing and type in Golf ball patterns....there are lots other places out there too. try Google image search....
PostPosted: Thu Jun 09, 2011 5:35 pm  (#7)
Here is mine. I can't get the text as good as I want it but I will work on it some more.Image
PostPosted: Fri Jun 10, 2011 12:20 am  (#8)
Did you use the paths tool for creating the lettering or did you just use a certain font?
Cool result. :)
PostPosted: Fri Jun 10, 2011 12:45 pm  (#9)
i used the font arista from dafont.com and ive been working on the golf ball pattern and im pretty close but not quite there yet
PostPosted: Fri Jun 10, 2011 1:20 pm  (#10)
Lighten up the insides of the dimples to one color and i think that will be about right. :)
PostPosted: Fri Jun 10, 2011 1:37 pm  (#11)
This golf ball worked out nicely. I shrank it to fit the text.
golf ball image.
PostPosted: Fri Jun 10, 2011 6:34 pm  (#12)
Just for the Challenge, I created this seamless texture using GIMP's Mosaid Mosaic {never said I was a good speller; lol) filter (and some G'MIC acrobatics {i.e., don't ask}) and used it along with plastic wrap and many other things to for the G. :)
PostPosted: Fri Jun 10, 2011 6:50 pm  (#13)
Here's the best golfball that I could render using the above texture, Mathmap Distort, Plastic Wrap Script-fu, and Gradient Overlay with above result set to Darken and adjusted opacity. :)
PostPosted: Fri Jun 10, 2011 7:41 pm  (#14)
Very nice Lyle!
I'm back I think
PostPosted: Fri Jun 10, 2011 9:29 pm  (#15)
Thanks Willy. I did modify the texture some and posted it at my Deviant. Also, did a mirror and strait tile blend to create this golf ball (for that varing shade effect) using the updated texture. :)
PostPosted: Fri Jun 10, 2011 11:26 pm  (#16)
I cant get that plastic-wrap script to run
PostPosted: Fri Jun 10, 2011 11:49 pm  (#17)
Wish I could help you Akky; Maybe you could post you error and maybe a guru here can help you get it to work. You can also try to use G'MIC's Relief Light preset since it gives very similar results. :)
PostPosted: Sat Jun 11, 2011 11:01 pm  (#18)
that pattern works great! i didnt even think of using plasti wrap to get the ball look more shiny!
PostPosted: Sun Jun 12, 2011 1:12 am  (#19)
Thanks Jacob. Now for a confession. A few years, when I was pursuing space art and looking for some cool planet textures, I ran across this site and saw this cool 3D golfball and I desperately tried to emulate the result using GIMP but at that time failed. Picked up so many more tricks since then and you gave me the inspiration to try again. Just now noticed that the dimples of your cool text example and a few golfballs were hexagonal, while others are dimple including this model. Don't golf myself so don't which is right or wrong, but like the hexagonal dimples better anyway. :)
PostPosted: Sun Jun 12, 2011 11:44 am  (#20)
i never knew golf balls had hexagon dimples but i searched golf ball texture in google so i could recreate it and it gave me a bunch of hexagon grids
