It is currently Thu Nov 19, 2026 7:04 am
 Post subject: make pointer bigger ??
PostPosted: Wed Jul 21, 2021 6:22 am  (#1)
the pointer in gimp is not that big, since i make videos with tutorials i would like a bigger pointer.
can i make the pointer bigger somewhere?
thanks in advance
 Post subject: Re: make pointer bigger ??
PostPosted: Wed Jul 21, 2021 7:17 am  (#2)
I don't know if it's possible > https://gitlab.gnome.org/GNOME/gimp/-/issues/3742
You might want to play with HiDPi of your operating system (that would be my way to go)
Or install tools for it (on Linux by default we got some "Universal Access" tools, strong contrast, magnifiers, bigger letters, bigger everything...) I don't know for Windows/mac
Patrice
PostPosted: Wed Jul 21, 2021 7:36 am  (#3)
Maybe make it more noticable:
Pointerstick https://www.portablefreeware.com/index.php?id=2195
Looks like this: https://i.imgur.com/ez4Ybz7.mp4
PostPosted: Wed Jul 21, 2021 1:41 pm  (#4)
thanks for the reply,but i thought maybe i could enlarge the pointer like we can enlarge the tools but apparently not so :( :(
PostPosted: Wed Jul 21, 2021 3:46 pm  (#5)
You can change the size of the pointer within Windows itself,
which will show up only for you and not during recording.
Some screen recording applications allow you to highlight the cursor while you record.
