It is currently Thu Nov 19, 2026 11:53 am
 Post subject: Rose Ball.
PostPosted: Thu Jun 09, 2011 5:47 pm  (#1)
Started a thread at DPR's Retouch forum but thought you all would like to play too. Earlier, I made a quick quip to the Wal-Mart lady greeter while she was sorting and dumping some roses (said, is that one for me?), and she gave me this one (which is now in a jar of water). Thought I would share this one with you all for play. It's SOOC with EXIF intact (so maybe on the bland side), but I won't share the RAW (not going to share a 20MByte file; sorry). If you want to play, I believe the jpg is good enough.
Source Image: http://img42.imageshack.us/img42/1357/l1000438.jpg
Seamless Texture (click on thumbnail for it for it's Deviant):
And, here is the Rose Ball:
Uploaded with ImageShack.us
 Post subject: Re: Rose Ball.
PostPosted: Thu Jun 09, 2011 11:50 pm  (#2)
I created another seamless texture w/ the help of Fractal Trace for this more random like sphere result. :)
Droste/Fractal Trace Texture (click on the thumbnail for it's Deviant):
PostPosted: Fri Jun 10, 2011 12:16 am  (#3)
Wow that is really cool Lyle! :)
PostPosted: Fri Jun 10, 2011 10:49 am  (#4)
Thanks Rod. :)
PostPosted: Fri Jun 10, 2011 2:25 pm  (#5)
Neat effect. My camera will take RAW but I never used it because I couldn't find much to support it but now days there is a lot. RAWTherapee, photivo and Xnview all work with it. RAW and TIF for me are the same size file (23 meg) so I'm still deciding which way to go. I know RAW has a lot of advantages, I guess I just need to make the move. My little handy dandy pocket sized fixed focus spare camera only does JPG, it will do like 3000 of them and I have to batch convert them every time I take them off the memory chip but that's not a big deal. This concludes my pointless babble, carry on.
PostPosted: Fri Jun 10, 2011 2:54 pm  (#6)
I threw a little Red-field, and GMIC together and came up with this. :)
Sorta pretty.
PostPosted: Fri Jun 10, 2011 2:55 pm  (#7)
Ahh i see i didn't get quite all the white spots out.
Oh well. :P
PostPosted: Fri Jun 10, 2011 3:12 pm  (#8)
I like it with the white! Clean it up a bit, the white is a bit finicky in places and have it huge and I would love it as a desktop background
I'm back I think
PostPosted: Fri Jun 10, 2011 3:29 pm  (#9)
Man I'm jealous of you fractilus owners. lol
Really like that one Rod. :)
PostPosted: Fri Jun 10, 2011 3:32 pm  (#10)
it does some neat things but it requires some fooling with to get it perfect.
PostPosted: Mon Jun 13, 2011 7:44 am  (#11)
I've had a quick go at doing something with the Rose Ball
File comment: Rose Ball - my take
All in GIMP using Difference of Gaussians edge detect, curves adjustments, stroked selection and a layer in Value mode.
Kevin
