It is currently Thu Nov 19, 2026 6:57 am
 Post subject: Digital Watercolour Paintings (Watercolour Outcomes)
PostPosted: Sun Aug 15, 2021 9:29 am  (#1)
Due to the interest in the watercolor effect, I open this thread as an attachment to jvid graphic Effects only to be used for watercolor effects.
Please feel free to explain your methods and / or ask any questions that may arise to achieve such beautiful results.
Many other people will be able to benefit from it.
For this purpose this thread is at your disposal.
Thanks a lot, :tyspin
:paint
 Post subject: Re: Digital Watercolour Paintings (Watercolour Outcomes)
PostPosted: Sun Aug 15, 2021 9:59 am  (#2)
These two outcomes are different. I prepared the zone of the picture before running the filter Jvid_L.
When I had the zone visble of the picture, merged it on a white layer. Then ran the filter. It was an experiment.
felix-mittermeier-1vT8aHuXEOI-Watercolour_Graphic_Effect_Jvid_LA_Sepia.jpg [ 796.35 KiB | Viewed 4335 times ]
felix-mittermeier-1vT8aHuXEOI-Watercolour_Graphic_Effect_Jvid_LA.jpg [ 1.41 MiB | Viewed 4335 times ]
PostPosted: Sun Aug 15, 2021 1:01 pm  (#3)
Very good idea, Issabella; the success of your process L/LA should be "honored" by a specific thread dedicated to any enthusiast of digital watercolour paintings.
Good start yours.
PostPosted: Sun Aug 15, 2021 1:17 pm  (#4)
Here my first contribution.
Being a filter man, I operate obviously on the filter itself to personalize.
Hence I have added a texture to simulate the paper on which the painting is done (I used a Fabriano paper). The idea has been stolen from Lula, who first realized the concept and was immediately followed by Ella and Issabella with excellent results. They use texturizer as you have seen on the JVID thread
Then I modified the frame overimposing an oval white area a little blurred.
Then I created a new from visible and set the LAYER_MODE to Screen to lighten the result.
2021-08-15 20-02-47 beautiful-view-of-the-mountains-and-the-church-on-giau-pass-1080x591 with JVID effect LA (Watercolour Graphic Effect, aged).jpg
2021-08-15 20-02-47 beautiful-view-of-the-mountains-and-the-church-on-giau-pass-1080x591 with JVID effect LA (Watercolour Graphic Effect, aged).jpg [ 742.39 KiB | Viewed 4299 times ]
PostPosted: Sun Aug 15, 2021 1:24 pm  (#5)
My second contribution.
Applied the following modifications to the LA .xcf result:
- Median Blur on the Frame
- VIVID_LIGHT mode on the Ageing pattern
- Added GEGL Chroma (10) to the Base layer
2021-08-15 20-18-34 canal-grande-basilica-di-s-maria-della-salute-in-venice-italy with JVID effect LA (Watercolour Graphic Effect, aged).jpg
2021-08-15 20-18-34 canal-grande-basilica-di-s-maria-della-salute-in-venice-italy with JVID effect LA (Watercolour Graphic Effect, aged).jpg [ 1.08 MiB | Viewed 4296 times ]
PostPosted: Mon Aug 16, 2021 12:26 am  (#6)
Third experiment.
Applied these variations to the .xcf:
- Frame: Median Blur
- Paper: opacity 100%
- Ageing: layer mode LUMINANCE
- Base: more brightness
2021-08-16 07-17-44 pexels-photo-888899 with JVID effect LA (Watercolour Graphic Effect, aged).jpg
2021-08-16 07-17-44 pexels-photo-888899 with JVID effect LA (Watercolour Graphic Effect, aged).jpg [ 666.13 KiB | Viewed 4268 times ]
PostPosted: Mon Aug 16, 2021 1:10 am  (#7)
Applied the following changes to .xcf produced by the filter:
- overimposed a second frame (we call here "frame" only the white margin around the image)
- set off the ageing layer
- added some red and yellow to tha Base
- activated the top layer and set to SCREEN
- modified a bit the colours
2021-08-16 07-52-40 pexels-photo-984944 with JVID effect LA (Watercolour Graphic Effect).jpg
2021-08-16 07-52-40 pexels-photo-984944 with JVID effect LA (Watercolour Graphic Effect).jpg [ 740.7 KiB | Viewed 4261 times ]
PostPosted: Mon Aug 16, 2021 1:33 am  (#8)
Very nice results, Dinasset. :coolthup
I set opacity lower to ageing layer.
applied more luminosity to base layer
duplicated frame and applied blur.
paulius-dragunas-Nhs0sLAn1Is-Watercolour_Graphic_Effect_Jvid_LA.jpg [ 595.08 KiB | Viewed 4254 times ]
PostPosted: Mon Aug 16, 2021 2:48 am  (#9)
Changes to .xcf outcome:
- top layer activated and set to ADDIOTION at 80%, plus added MEDIAN BLUR at 25
- paper set to LCH LIGHTNESS at 25%
- ageing layer set to GRAIN_MERGE
2021-08-16 09-34-00 pexels-photo-8889029 with JVID effect LA (Watercolour Graphic Effect, aged).jpeg
2021-08-16 09-34-00 pexels-photo-8889029 with JVID effect LA (Watercolour Graphic Effect, aged).jpeg [ 437.54 KiB | Viewed 4235 times ]
PostPosted: Mon Aug 16, 2021 2:52 am  (#10)
Standard outcome of the filter (I liked the result as such).
2021-08-16 09-49-36 rose-yellow-flower-petals-60909 with JVID effect LA (Watercolour Graphic Effect, aged).jpeg
2021-08-16 09-49-36 rose-yellow-flower-petals-60909 with JVID effect LA (Watercolour Graphic Effect, aged).jpeg [ 654.84 KiB | Viewed 4234 times ]
PostPosted: Mon Aug 16, 2021 3:14 am  (#11)
Outcome standard.
2021-08-16 10-06-03 pexels-ashley-fontana-705766 with JVID effect LA (Watercolour Graphic Effect, aged).jpeg
2021-08-16 10-06-03 pexels-ashley-fontana-705766 with JVID effect LA (Watercolour Graphic Effect, aged).jpeg [ 841.79 KiB | Viewed 3547 times ]
After applying the following changes:
- top layer activated, inverted colours, set mode to DIVIDE at 5% (it looks interesting IMO)
2021-08-16 10-06-03 pexels-ashley-fontana-705766 with JVID effect LA (Watercolour Graphic Effect, aged)-PP.jpeg
2021-08-16 10-06-03 pexels-ashley-fontana-705766 with JVID effect LA (Watercolour Graphic Effect, aged)-PP.jpeg [ 723.58 KiB | Viewed 3547 times ]
PostPosted: Mon Aug 16, 2021 4:16 am  (#12)
Very interesting your result with inverted colours. I will try it. :yes
felix-mittermeier-JYx2nrMrGZo-Watercolour_Graphic_Effect_Jvid_La.jpg [ 681.84 KiB | Viewed 3541 times ]
PostPosted: Mon Aug 16, 2021 4:17 am  (#13)
kristof-tuerlinckx-Qyymo_Z_aqQ_Watercolour_Graphic_Effect_L.jpg [ 761.43 KiB | Viewed 3541 times ]
PostPosted: Mon Aug 16, 2021 4:18 am  (#14)
:paint
lightscape-MfQH4E1WaJs-Watercolour_Graphic_Effect_L.jpg [ 737.46 KiB | Viewed 3541 times ]
pink-3383825_Watercolour_Graphic_Effect_Jvid_LA.jpg [ 602.37 KiB | Viewed 3541 times ]
PostPosted: Mon Aug 16, 2021 6:16 am  (#15)
:paint
b831b2fe101c79e572a37_Watercolour_Graphic_Effect_L.jpg [ 1.23 MiB | Viewed 3536 times ]
01e1b0f1748df5e0049_Watercolou_Graphic_Effect_L.jpg [ 598.97 KiB | Viewed 3536 times ]
PostPosted: Mon Aug 16, 2021 6:18 am  (#16)
c0fdc78d52583887b420_Watercolour_Graphic_Effect_L.jpg [ 1.17 MiB | Viewed 3536 times ]
4eecb41e89b849284f38ea8a_Watercolour_Graphic_Effect_L.jpg [ 1.15 MiB | Viewed 3536 times ]
PostPosted: Tue Aug 17, 2021 7:13 am  (#17)
:paint
PostPosted: Tue Aug 17, 2021 8:20 am  (#18)
So beautiful, Ella. You get the esential look seems so realistic. :paint :coolthup
PostPosted: Tue Aug 17, 2021 8:22 am  (#19)
:cool
asian-shin-se-gyeong-korean-women-portrait_Watercolour_Graphic_Effect_L.jpg [ 727.74 KiB | Viewed 3493 times ]
PostPosted: Tue Aug 17, 2021 8:48 am  (#20)
And you've mastered the portraits, Issa. They are really very beautiful :hi5
And my favorite one ...
