It is currently Thu Nov 19, 2026 7:04 am
 Post subject: OPEN GIH FILES
PostPosted: Tue Aug 24, 2021 8:58 am  (#1)
my question is simple, how can i open GIH files
thanks in advance for replying,gimper66
 Post subject: Re: OPEN GIH FILES
PostPosted: Tue Aug 24, 2021 9:08 am  (#2)
Use (File > Open) and select the gih file.
You can also set file associations so that if you double-click the gih file Gimp will open it.
PostPosted: Tue Aug 24, 2021 11:47 am  (#3)
thanks blighty
