wyatt wrote:
This isn't the best work but im learning so yeah. LOL
If you have any suggestions for me to make this look better then im all ears!
There are four kinds of lighting: ambient (colour), diffuse (shadows and highlights), specular (glossy reflections), and emissive (glowing).
For glassy/shiny objects you need the first 3, but your drawing only has the first 2.
Also, to make a hollow glass ball, you will have these reflections on both the inside and outside.
Here is an example showing the missing specular lighting:
and the same with the layers spread apart to show the different lighting:
The last thing glass needs to look realistic is refraction (distortion because of bending light).
I took a quick photo of liquid in a wineglass since I don't have any glass balls handy
-Rob A>
