It is currently Thu Nov 19, 2026 6:58 am
 Post subject: 6 STEP BOWL ERROR
PostPosted: Sat Jan 15, 2022 4:30 am  (#1)
the operation has nice results, but here it doesn't work for me, I keep getting the same error message.
i work with gimp 2.10.30
I hope it can be solved, thanks in advance
gimper66
 Post subject: Re: 6 STEP BOWL ERROR
PostPosted: Sat Jan 15, 2022 5:27 am  (#2)
I also asked that question but you should not use this. you need to go to filters > map > map object > sphere
PostPosted: Sat Jan 15, 2022 8:31 am  (#3)
jappaloe 63,this is not what i'm looking for, it's the bowl i want to make the way the tutorial is intended
PostPosted: Sat Jan 15, 2022 8:56 am  (#4)
Filter was last updated in 2012. Maybe it doesn't work with the recent GMIC. Throws an error for me now too.
PostPosted: Sun Jan 16, 2022 3:18 am  (#5)
Update your version of Gmic to 3.0.1 and it should be ok now. The bug has been fixed
PostPosted: Sun Jan 16, 2022 5:18 am  (#6)
If you download G'mic 3.0.2 it should work!
