It is currently Thu Nov 19, 2026 6:36 am
 Post subject: ERROR MESSAGE WHEN CREATING AN OLDER TUTORIAL
PostPosted: Thu Jan 27, 2022 6:27 am  (#1)
I WORK WITH GIMP 2.10.30 AND WANT TO CREATE A TUTORIAL EXECUTED WITH 2.8.2
everything goes well until almost the end.
i want to achieve this
but in the end I get this, which of course is affected by the error message
I understand that there are filters and scripts that no longer work properly with the new gimp implementation, but they can potentially be fixed so that they can be used normally again.
if you watch the video, the error occurs during the edit between 7.18 to 7.50
https://youtu.be/5djSFwqMlJk
the youtube video with the tutorial.
pending a solution, I would like to thank the specialists in this matter gimper66
 Post subject: Re: ERROR MESSAGE WHEN CREATING AN OLDER TUTORIAL
PostPosted: Thu Jan 27, 2022 7:26 am  (#2)
I made it too.. have some older files from 2.8. used in Gimp in 2.10. And actually I could totally make it. Everything works
PostPosted: Thu Jan 27, 2022 7:33 am  (#3)
yes in the older version it will work but with the new gimp version it doesn't work anymore,should know what scripts or whatever i should modify
PostPosted: Thu Jan 27, 2022 8:03 am  (#4)
No need to use old scripts / plugins / modify anything.
The time you gave 7' 15" > 7' 40" is creating the background. Standard Gimp 2.10 tools.
In 1 minute https://i.imgur.com/7e6EAmT.mp4
Even the text, instead of iWarp use the GEGL Warp Tool.
PostPosted: Thu Jan 27, 2022 2:23 pm  (#5)
as shown in the video I do the same operation but I get an error message and a different outcome.
I also get the same error message every time
https://youtu.be/22_S7Kukpk8
PostPosted: Fri Jan 28, 2022 5:01 am  (#6)
Jappaloe63 wrote:
I made it as well.. have some older files from uut 2.8. used in Gimp in 2.10. And actually I was able to make it completely. Everything works
Cool Jappaloe63 :coolthup
PostPosted: Fri Jan 28, 2022 8:47 am  (#7)
Couldn't even find iwarp! Where is it now?
PostPosted: Fri Jan 28, 2022 1:01 pm  (#8)
can you show us how to use GEGL Warp rich? Please... :( I know :oops:
I did this using default settings. How do you use it to make the warping in the middle of the letters?
PostPosted: Fri Jan 28, 2022 2:54 pm  (#9)
Hi Gimper! These Legacy plugins from the older GIMP versions do not work right with latest versions of GIMP :gaah
The quick fix for this is to "Reset the filter": Go to Filters and on top click on "Reset All Filters", then try to re-apply on the layer. You might have to apply the filter twice for the background.
PostPosted: Fri Jan 28, 2022 5:16 pm  (#10)
sallyanne wrote:
[align=center]can you show us how to use GEGL Warp rich? Please... :( I know :oops:
Something like this https://youtu.be/a_wxrpOTeXQ edit: Forgot the drop shadow, but it's the general idea.
Busy day Fridays ;) packing in for now.
PostPosted: Fri Jan 28, 2022 6:07 pm  (#11)
I would it explained the same way as rich2005, but I thought by now, experienced users have know how to use the Warp transform tool.
PostPosted: Fri Jan 28, 2022 11:41 pm  (#12)
Tool I don't use and I am not 'experienced' ;
Oh that tool. I had it turned off which is why i couldn't find it so used the one under 'map' :oops:
Thank you rich.
I think I got it now only I used the wrong size brush. (My thinking was it needed to fit inside the letters ;) )
Did a variation of this but will put it in my other thread
PostPosted: Sat Jan 29, 2022 3:44 am  (#13)
thanks everyone for the replies, i have reset my filters and everything works perfectly now
gimper66
