It is currently Thu Nov 19, 2026 6:57 am
 Post subject: SCROLLING SCRIPT-FU dialog modification
PostPosted: Fri Feb 18, 2022 8:15 am  (#1)
can someone give me the SCROLLING SCRIPT-FU dialog modification
I'm supposed to be able to make the window smaller so that I can reach the ok button
thanks in advance,gimper66
 Post subject: Re: SCROLLING SCRIPT-FU dialog modification
PostPosted: Fri Feb 18, 2022 8:35 am  (#2)
https://www.gimpscripts.net/search?q=scrolling
PostPosted: Fri Feb 18, 2022 10:44 am  (#3)
i downloaded script-fu scrolling interface and put it in my plugin folder, but it still doesn't work
jappaloe63,Thanks for the quick response
PostPosted: Fri Feb 18, 2022 12:11 pm  (#4)
Wrong directory my friend! You need to place it in your main GIMP 2 in
C:\Program Files\GIMP 2\lib\gimp\2.0\plug-ins\script-fu
1. Before you place it in the right directory:
Delete the one you have in you User GIMP 2.10 profile folder:
C:\Users\YourName or User\AppData\Roaming\GIMP\2.10\plug-ins
2. Rename existing extension to ".old" then place the "Script-Fu Scrolling Interface" in the directory show bellow:
Click on the link and you will get an explanation of it by MareroQ.
https://www.gimpscripts.net/search?q=script-fu
PostPosted: Fri Feb 18, 2022 12:12 pm  (#5)
To be correct, put the plugin in C:\Program Files\GIMP 2\lib\gimp\2.0\plug-ins\script-fu (rename the existing file to save it)
However, your installation seems ok, I can see the scroll bar. Leave it as it is.
All you have to do is resize the window to show the bottom with the OK button.
example: https://i.imgur.com/AJSpWhE.mp4
PostPosted: Fri Feb 18, 2022 12:32 pm  (#6)
Yes need to "rename" the existing file. That is what I meant rich2005, thank you.
PostPosted: Fri Feb 18, 2022 2:03 pm  (#7)
https://stefansundin.github.io/altdrag/
I use Altdrag... I like it
PostPosted: Fri Feb 18, 2022 4:19 pm  (#8)
If two versions are installed (very bad practice), the higher one (the first one on the list) in Preferences will be loaded.
PostPosted: Sat Feb 19, 2022 3:48 am  (#9)
I also think the problem is along those lines. A existing modified script-fu.exe is already installed (somewhere). gimper66's first screenshot shows the dialogue with a scroll bar. All that is needed is re-size the dialogue window.
More worrying is the second gimper66 screenshot. All those folders in user plugins and what looks like a non-understanding of how that works ;)
The folder name must be the same as the plugin and in Windows without the extension.
script-fu.exe goes in a folder script-fu
ofn-bend-path.py goes in a folder ofn-bend-path
script-fu.exe in a folder "script-fu exe 18-02-2022" is not going to work.
This is still not mandatory for Gimp 2.10 but will be for Gimp 3 (when it comes) Makes sense in Windows where there might be lots of dependencies like the gimp_gmic_qt plugin but there are not many like that. Looking at gimper66's screenshot maybe a case for a cleanup ;) A doc folder ? is there a doc.exe or doc.py plugin ?
PostPosted: Sat Feb 19, 2022 10:09 am  (#10)
the computer isn't mine, it's a friend who also started gimp together with me.
I don't like going into someone else's computer, but what we did do is < reset plug-in-folders > and it works, problem solved.
Thanks everyone for the comments,gimper66
