It is currently Thu Nov 19, 2026 4:52 am
 Post subject: Tiger Dots.
PostPosted: Wed May 11, 2022 7:03 pm  (#1)
It's been a while since I did a straight stipple (thanks again to Voronoi Stippler). For the curious, there's exactly 12000 dots. My challenge to you is to prove me wrong. lol
ref: https://pixabay.com/photos/tiger-head-p ... r-3244048/
https://www.flickr.com/photos/163034485 ... 85/sizes/o
 Post subject: Re: Tiger Dots.
PostPosted: Wed May 11, 2022 7:35 pm  (#2)
Lyle, the tiger is so neat! Beautiful! How did you do that?
PostPosted: Wed May 11, 2022 8:02 pm  (#3)
Thanks Pat. Cannot seam to find the original thread where I used Voronoi Stippler. Still, a log of help can be gleaned from the Traveling Salesman Problem thread: viewtopic.php?f=22&t=1128&hilit=voronoi
Also this thread: viewtopic.php?f=11&t=13255&hilit=voronoi+stippler
Unfortunately, Saliences site no longer exists; still there's plenty of stippler programs out there; below's one such place. :)
https://www.evilmadscientist.com/2012/s ... rocessing/
PostPosted: Thu May 12, 2022 1:19 am  (#4)
Pat, you may also use the standard GIMP (Gegl) Newsprint to get very interesting results.
Play with parameters and mode.
PostPosted: Sat May 14, 2022 10:15 pm  (#5)
Thank you, Lyle and Dinasset! I will look up the info from both of you and see what I can do.
PostPosted: Sat May 14, 2022 10:41 pm  (#6)
Hi Pat,
You can also try this:
https://www.gimpscripts.net/2020/10/vor ... 1-new.html
Old plug, but still works for Gimp-2.10.30
PostPosted: Sun May 15, 2022 5:55 am  (#7)
Thank you MareroQ. I will check this one also
PostPosted: Sun May 15, 2022 6:39 am  (#8)
@MareroQ
I must have missed that plugin first time round ;) Anyway, using Kubuntu 20.04 / Gimp 2.10.30 (from PPA) / voroni-stippler (...gets migrated from previous machine to new...to...)
Your plugin 0.2 version working very well Some output with snipped of source image https://i.imgur.com/uGd3KLC.jpg
PostPosted: Sun May 15, 2022 7:08 am  (#9)
Hi Rich,
Glad you ran it on Linux (I failed in Ubuntu :hoh ).
Can You include the used voroni-stippler files?
PostPosted: Sun May 15, 2022 7:30 am  (#10)
MareroQ wrote:
Hi Rich,
Surething, I have various files going back but this is what I am using.
the 6 libboost files go in usr/lib
voronoi-stippler goes in usr/bin (or install them somewhere else and use symlinks to usr/lib & usr/bin)
Other than that, run in a terminal and check for other dependencies.
voroni_stippler_lin_64bit.zip [389.76 KiB]
Downloaded 280 times
PostPosted: Sun May 15, 2022 8:25 am  (#11)
Circlism Variation
Thought I would run 3 size passes using the preceding mask of one result as a mask for the next. Still a work in progress. Just had an epitome (tried this before; guess I have a clearer mind now; lol). No where near Ben Heine's work, but he places the dots manually and I'm just too d@mn lazy to do so. lolololololol
PostPosted: Fri Oct 28, 2022 6:30 am  (#12)
MareroQ wrote:
Hi Pat,
Indeed it does, and very nicely too!
Linux user here: voronoi_stippler accepts decimal input for option -z, so PF_FLOAT instead of PF_INT.
HA
PostPosted: Wed Mar 29, 2023 2:16 pm  (#13)
Didn't feel like starting another thread; just sharing yet another result (w/ after effect tweaks; it's what I do) using G'MIC's new Packed Ellipses preset. :)
