It is currently Thu Nov 19, 2026 6:23 am
 Post subject: RPG backgrounds and critters
PostPosted: Fri Jul 22, 2022 7:00 am  (#1)
I'm currently game-mastering a fantasy RPG for some friends (we play online). It's a classic dungeon crawl but we play with a lot of role playing and 'theater of the mind' combat (so no grids or miniatures). I took to making a few bits of artwork to help guide their imagination. Nothing fancy, just quick sketchy images to relay the feel and creepiness of the setting.
The entrance to the tomb. I use FoundryVTT, which means that I can adjust the light, add light sources and make it rain etc.
The oppressive inside of the tomb. Again, in Foundry, I can add flickering light sources to make this animate and 'pop' a little more.
Rather than go with bog-standard skeletons, they encountered this ... thing on the left there. Which was a lot more unnerving for the players than a simple walking skeleton! The right one is the upgraded version coming up on a later level ... :D
This little fellow was surprisingly friendly, and kindly offered to eat the character's feet or hands whenever they wanted to - he'd be honored to. Clearly an offer of friendship if I ever saw one.
Waterlogged and dry versions of the second level, which they find through a hole under a hulking statue.
... Surely that's just a statue, right?
Scenes from the third and final level of the tomb. We'll see if I make more images for that when they get there! :)
Update: Posted some more images here: viewtopic.php?f=11&t=20075
Griatch
 Post subject: Re: RPG backgrounds and critters
PostPosted: Fri Jul 22, 2022 7:24 am  (#2)
Cool as usual. :bigthup I'm sure the gamers will appreciate those drawings. :)
PostPosted: Fri Jul 22, 2022 8:48 am  (#3)
Wow, impressive work! You do it all with the paint tools? The second level pictures look awesome, the lighting is great.
PostPosted: Fri Jul 22, 2022 9:02 am  (#4)
I can't fathom the amount of work you did on those images. Well done :clap
Patrice
PostPosted: Sun Jul 24, 2022 8:51 am  (#5)
I hope they do too, but I usually don't tell them I made them. :D
Griatch
PostPosted: Fri Jul 29, 2022 4:59 am  (#6)
My previous comment was accidentally removed, so posting anew:
Yep, done with paint tools and an extra layer to help testing out lights.
Glad you like them! This was not so much work though, they are pretty sketchy and I only spent about an hour apiece on them. A more detailed image is in the 8h range for me.
Griatch
