It is currently Thu Nov 19, 2026 6:23 am
 Post subject: Using GnuTux 3D-Extrusion scm filter...
PostPosted: Sat Jul 23, 2022 1:27 am  (#1)
on a font called "Abduction 2002" and GnuTux's SCM 3D-Extrude filter. This font is unique in that it is broken into separate sections. Example.
And running GnuTux 3D-Extrude filter on text filled with a pattern.
This one i separated the layers of the type a bit more.
Still works really well in Gimp-2.10.32. Thanks Tux wherever you are! :hi5
 Post subject: Re: Using GnuTux 3D-Extrusion scm filter...
PostPosted: Sat Jul 23, 2022 4:05 am  (#2)
Cool Rod :) Yes we often use it.
