It is currently Thu Nov 19, 2026 11:52 am
 Post subject: Water Text Effect
PostPosted: Sat Jun 18, 2011 7:15 pm  (#1)
 Post subject: Re: Water Text Effect
PostPosted: Sat Jun 18, 2011 7:20 pm  (#2)
I like it very much, but it seems to me that the paper is raising up too much within the water.
PostPosted: Sat Jun 18, 2011 7:24 pm  (#3)
i agree, i used the layer effects with bevel and emboss and i had the darker areas a little too dark
PostPosted: Sun Jun 19, 2011 3:51 am  (#4)
A YouTuber called xgeous has a good tutorial on creating water text. It's long, but the results are awesome. I did it once but deleted the image a while ago. Worth checking out and it's good practice for other GIMP features.
Might check some of his other tutorials, he does some cool stuff. The videos are long, but he goes slowly so you can follow along. I've done a few of his tutorials and learned a lot.
PostPosted: Sun Jun 19, 2011 6:28 am  (#5)
Meet The Gimp also has one.
It looks to me like you should set the opacity a little lower for a more transparent look around the white edges Jacob. :)
