It is currently Thu Nov 19, 2026 6:26 am
 Post subject: Another try at a space pic
PostPosted: Sun Dec 18, 2022 11:04 am  (#1)
This time from scratch. I dont have any astronomy programs except the 'light & shadow filter' and also the map to sphere. I also used the popcorn fractal as the base for the background.
If you want to see it larger it is here https://www.deviantart.com/sallyanneste ... -941517495
 Post subject: Re: Another try at a space pic
PostPosted: Sun Dec 18, 2022 11:31 pm  (#2)
Crazy wonderful result, Sallyanne; definitely digging the swirly planet and Surreal space areas. :)
PostPosted: Mon Dec 19, 2022 12:38 am  (#3)
Aww thank you Lyle.
