It is currently Thu Nov 19, 2026 6:26 am
 Post subject: A SIGN UNWANTED APPEARS
PostPosted: Sat Feb 04, 2023 12:22 pm  (#1)
oops, suddenly there is this little sign while I'm gimping.
I hadn't noticed it at first,I wonder how it got there, what is its meaning and how can I remove it while I'm working on a design (without the risk of my work being deleted or damaged)
thanks in advance
 Post subject: Re: A SIGN UNWANTED APPEARS
PostPosted: Sat Feb 04, 2023 1:03 pm  (#2)
That is a sample point, showing colour properties in the sample point dock. Which you do not have showing.
see: https://docs.gimp.org/en/gimp-sample-point-dialog.html
You get them by ctrl-(drag from the ruler)
You can hide them from the View menu
You can drag them off the canvas using the color-picker tool. Hover over the sample point until it changes color, click and drag off the canvas.
These only exists inside Gimp, saved with a Gimp .xcf Not there when you exported a file.
a 30 second demo https://i.imgur.com/5fTxrwg.mp4
PostPosted: Sun Feb 05, 2023 3:11 am  (#3)
rich2005
thanks for the clear explanation and the attached video.
gimper
:tyspin :tyspin
