It is currently Thu Nov 19, 2026 6:23 am
 Post subject: Tigerdots
PostPosted: Mon Feb 20, 2023 12:47 am  (#1)
ref: https://images.pexels.com/photos/205510 ... jpg&fm=jpg
Might have over-compensated for the shadows. lol
Believe I figured out a better way to create the dot mask by running G'MIC's b/w dither and using that result to run Shapism. :)
 Post subject: Re: Tigerdots
PostPosted: Mon Feb 20, 2023 2:06 am  (#2)
I really like this one... How do you make something like this?(Maybe I missed something)
PostPosted: Mon Feb 20, 2023 2:40 am  (#3)
In G'MIC, there is a preset (under Art subdirectory) called Shapism. The problem with that preset is it usually yields unfocused results. I use another G'MIC preset called b/w dither and feed that into Shapism instead (using transparent background color instead of the default black). Create a mask by chosing Alpha to Selection and highlighting the GIMP toggle selection option, I copy that and then untoggle and selection none. I then paste for the mask. I then run Threashold (moving slider left to brighten) for the mask and run Blend (Shape Average) with original image (Blend (Shape Average) is located in Testing folder>Lylejk; David saved this preset for me when he went another direction with the preset; I like the original behavior better, and definitely appreciate that David saved this preset under the Testing section). I then add layer mask and past the mask in that to smooth out the dots. Maybe the programmer gurus here can automate this flow. I do use a copy of the threshold mask and apply a convolution layered dot set to grain merge to push more details, but that's part of the secret sauce I use. lol
Create the convoluton layer by duplicating the original, and on the base layer I run Sharpen (Gradient) and set the top layer to Grain extract and merge down. I then used Blend (Shape Average) on the convolution layer with the threshold mask as mentioned to convert it to dots which I then set to Grain Merge over the colored dot result. This step, again, adds more perceived contrast/details to the dots as a whole (globally that is). :)
PostPosted: Mon Feb 20, 2023 2:55 am  (#4)
:coolthup
Oops, :oops: I didn't do your last step
by the way, How do you choose transparency instead of black?
PostPosted: Mon Feb 20, 2023 7:44 am  (#5)
Also, you used original as base layer which gives you more perceived details (but cheating). lol
Nice birdy, though. :)
PostPosted: Mon Feb 20, 2023 7:47 am  (#6)
Also, wasn't going to share this Gorilla, but why not. Only a clickable link to see it (and didn't want to start yet another thread). lol
hirez: https://www.flickr.com/photos/163034485 ... 83/sizes/o
https://www.flickr.com/photos/163034485 ... 1658479894
PostPosted: Mon Feb 20, 2023 9:25 am  (#7)
OK; will share Mufasa with you all; working on bringing out finer details such as the whiskers; still a work in progress. :)
https://www.flickr.com/photos/163034485 ... 47/sizes/o
PostPosted: Mon Feb 20, 2023 2:55 pm  (#8)
Thank you for your explanation...and this one is also beautiful!
PostPosted: Tue Feb 21, 2023 8:40 am  (#9)
Very cool lylejk, love your Mufasa :clap
So I did a try
I like this effect :hehe
Patrice
PostPosted: Thu Feb 23, 2023 12:21 am  (#10)
ok tried it again
Not sure I got the lines the right colour
Worked out why the colour but it isn't working for me. Will try another day
PostPosted: Thu Feb 23, 2023 5:43 am  (#11)
Really cool results Pix/Sallyanne. Instead of using dither, I tried using Stamp with 50% grain and got ever closer results to what I'm going for (not sharing those plays since I'm still tweaking). :)
edit (12 minutes later).
OK, here's the same tiger using the new masking technique (and increased the big dot size to 50 from 35). :)
